Sheared otter switch bolt
EDW3694
#1 Sheared otter switch bolt
Post by EDW3694 » Wed Feb 08, 2017 9:53 pm
While replacing the otter switch I've sheared one of the bolts off in the threads of the housing. I've ordered a new housing but can't source any new bolts. Barrett's and Manners' both say they are unavailable.
Does anyone know what size/thread they are or know where I could get hold of 3 new ones?
Also I've tried to attach a photo but the file is too large, how do I get over this problem
'72 S3 2+2 Regency Red
JagWaugh
Switzerland
#2 Re: Sheared otter switch bolt
Post by JagWaugh » Wed Feb 08, 2017 10:09 pm
I'm not sure about the SIII, but on the earlier cars they are #10 NC (i.e. 10-24) Should be fairly easy to source those.
#3 Re: Sheared otter switch bolt
Post by abowie » Thu Feb 09, 2017 2:49 am
Common problem; they weld themselves in there. #10 or 3/16" UNC (NOT UNF). You might satruggle to find hex headed bolts but if you can't you could just use Phillips.
V12 Epyte
#4 Re: Sheared otter switch bolt
Post by V12 Epyte » Thu Feb 09, 2017 7:00 am
1971 Series 3 FHC 2+2 RHD Manual
1971 Series 3 Roadster 2+2 RHD Manual
1986 Rover SD1 Vitesse Twin Plenum
EDW3694
#5 Re: Sheared otter switch bolt
Post by EDW3694 » Fri Feb 10, 2017 8:27 pm
Thanks for the info. Now have fitted a new housing, otter switch and bolts.
Run up to temperature and the fans came on and no leaks :bigrin:
EDW3694
#6 Re: Sheared otter switch bolt
Post by EDW3694 » Fri Feb 10, 2017 10:11 pm
http://s38.photobucket.com/user/simon_e ... sort=3&o=4
This is a pic of my car (hopefully, if I've sorted photobucket)
E-typeguy
#7 Re: Sheared otter switch bolt
Post by E-typeguy » Sat Feb 11, 2017 3:29 am
Nice car Simon. Hope to have mine looking like yours.
Wes
1972 Jaguar XKE coupe - Series III
Adamski
#8 Re: Sheared otter switch bolt
Post by Adamski » Sun Feb 19, 2017 8:18 pm
Looking good. I too sheared one of those bolts and as mentioned drilled it and got in a stainless self tapper.
It's also nice to have a switch with light to activate the fan relay and thus switch them on manually in traffic.
Adam
JagWaugh
Switzerland
#9 Re: Sheared otter switch bolt
Post by JagWaugh » Sun Feb 19, 2017 8:41 pm
Just for the sake of mentioning it, if the sheared fastener is ferrous, and the part isn't, you can dissolve the fastener.
https://forums.jag-lovers.com/t/xk-engi ... num/245409
42south
New Zealand
#10 Re: Sheared otter switch bolt
Post by 42south » Mon Feb 20, 2017 12:04 am
Hi Guys
If you are looking to upgrade to more modern/reliable componentry, check this link to Coolcat out. I fitted one to my V12 several years ago; replacement senders are a modern readily available part from Porsche.
https://tinyurl.com/zpgjxoh
Mark Brown
1971 S3 Etype
Son: when I grow up, I want to be a pilot
Dad: You’ll have to choose.
