Hello,
while cleaning the whole car and removing all parts from the backseats i detected that i've rust under the board behind the backseats. The one which is connected to the wooden board in the trunk.
Thanks!
Greets,
Stefan
How to remove the board behind backseats?
Topic author - Posts: 62
#1 How to remove the board behind backseats?
Jaguar E-Type S3 1971
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#2 Re: How to remove the board behind backseats?
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#3 Re: How to remove the board behind backseats?
Hi Stefan....not sure on the S3 but on my S2 2+2 remove the board over the spare wheel and the one next to it over the petrol tank....then you should see self tapping screws holding the panel down...remove these and see if you can lift the panel out.. Steve
Edit....if you look in the knowledge base section, there is a S3 parts catalogue.....look in the body section...there are drawings showing what i described above.....there is lots of S3 info there, including a full maintenance manual.....do you have your own maint manual....Steve
#4 Re: How to remove the board behind backseats?
Hi Steve,
thanks for your answer. I'll have a look in the knowledge base section - thanks for that.
Currently i can lift the panel from the trunk site - about 1-2cm. But it still holds on the site of the seats and i've now idea how it is fixed on that site. I don't want to pull it out and use raw violance.
Stefan
Stefan
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#5 Re: How to remove the board behind backseats?
Hi Stefan....on mine once i removed the 3 screws and slightly lifted it had to be pulled out hard in the photo u can see the lip it sits under...possibly slightly different to yours....can i see hinges in your photo, the screws may be holding it
#6 Re: How to remove the board behind backseats?
The photo is not my car ;-) but it looks nearly the same. OK i'll try to pull it right out to the direction of the trunk. Thanks a lot!
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#7 Re: How to remove the board behind backseats?
OK somebody used a lot of glue to fix the board. Need to check how to remove it.
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#8 Re: How to remove the board behind backseats?
OK i used a credit card to seperate the leather from the glue. Worked fine and now i was able to remove the board.
Thanks!
Thanks!
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
