Doorlock reversed / mirrored on each door / side?
Topic author - Posts: 62
#1 Doorlock reversed / mirrored on each door / side?
Hello,
my door lock is reverse on each side / door.
So on the left door i've to use the key in up position on the right door in the down position. I also have to lock in reverse direction.
Is this normal? Can i fix it?
Greets,
Stefan
Greets,
Stefan
Jaguar E-Type S3 1971
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#2 Re: Doorlock reversed / mirrored on each door / side?
Normal. 20 chracters
#3 Re: Doorlock reversed / mirrored on each door / side?
OK strange. Didn't expect this from a car like this. Are you sure?
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#4 Re: Doorlock reversed / mirrored on each door / side?
My '71 S3 has the same arrangement... I too thought it unusual but seems the way they built them, I wonder how much BL saved per car with this arrangement. Weirdly my '69 MGB has the more logical/expected arrangement.
'71 S3 OTS
#5 Re: Doorlock reversed / mirrored on each door / side?
same to me for my 67' MG MGB which has it in the correct way.
OK thanks. very strange
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
#6 Re: Doorlock reversed / mirrored on each door / side?
Noticed the same on mine this weekend, characterful....I like it.
S3 2+2 1971
Aston V8 Vantage 2006
Caterham Supersprint 1.7 1989
Jeep Wrangler TJ
S3 2+2 1971
Jeep Wrangler TJ
#7 Re: Doorlock reversed / mirrored on each door / side?
Yes.disaster123 wrote:OK strange. Didn't expect this from a car like this. Are you sure?
#8 Re: Doorlock reversed / mirrored on each door / side?
Yes quite normal, as unusual as it may seem.disaster123 wrote:Hello,
Greets,
Stefan
Can you fix it? Well if you change it you would break it not fix it.
John Mann
1972 S3 Jaguar E-Type 2+2
1976 Jaguar XJ4.2C
2007 Jaguar XKR Portfolio
1976 Jaguar XJ4.2C
#9 Re: Doorlock reversed / mirrored on each door / side?
Ok thanks. Just didn't expect this. My MG and VW have "corrrect" locks
VW Käfer 1200 1967
MG MGB 1967
VW Käfer 1200 1967
MG MGB 1967
