Power Steering Fluid
dooley1414
#1 Power Steering Fluid
Post by dooley1414 » Wed Oct 04, 2017 5:11 pm
Hi all I have a ex. US 1972 Series 3 V12 and was just wondering what was the best power steering fluid to get for it how much does the system take and is it the same fluid for the automatic gearbox? Many thanks in advance.... Des.
Ex. Texas Import 1971 Series 3 V12
Des. Suffolk.
Whitact
#2 Re: Power Steering Fluid
Post by Whitact » Fri Oct 06, 2017 7:11 am
ATF as for the autobox, capacity is small, less than a pint I think. Level adjustment is very sensitive due to the shape of the reservoir. A little at a time is best. I used a long rubber tube attached to the top of the ATF bottle to make it easier to avoid spilling it. Its not the easiest place to access, especially when hot.
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
JJC
#3 Re: Power Steering Fluid
Post by JJC » Sat Nov 25, 2017 10:38 pm
Most anything will do that will service an older GM power steering pump, as , of course, that's what they are.
Enjoy,
