Fuel line issue
MLBS3V12
#1 Fuel line issue
Post by MLBS3V12 » Sat Oct 07, 2017 6:37 am
I ve 2 problems on the right side fuel rail.
One is to find a nut to maintain the fuel line
The second one is to have the right size nut to fix the last tube on the fuel rail under the car.
I ve got a donor S3 for my restoration and it seems that the size of this parts were not the same. Now I ve sold the rest of the donor car. :-)
I clearly dont where I can find parts.
Thank you for your help.
Michel
Le chemin sera long!...
jagwit
#2 Re: Fuel line issue
Post by jagwit » Mon Oct 09, 2017 1:35 pm
SNG Barratt SNG
Martin Robey MR
Norman motors Norman
Best Regards
Philip
71 E-type V12 Coupe,
80 XJS (EFI by Megasquirt & EDIS-6 + 5sp manual overdrive)
73 Jensen Interceptor
74 Interceptor (EFI by Megasquirt + overdrive 4sp auto)
MLBS3V12
#3 Re: Fuel line issue
Post by MLBS3V12 » Fri Oct 27, 2017 4:26 pm
Thanks Philip
I've tried the 3 ones and many other ones in UK without succes...... :shrug:
I ve detailled furthermore into the technicall topic.
#4 Re: Fuel line issue
Post by mgcjag » Fri Oct 27, 2017 5:05 pm
Hi Michel....have a look here...you should be able to find what you need https://www.automec.co.uk/collections/b ... l-fittings
MLBS3V12
#5 Re: Fuel line issue
Post by MLBS3V12 » Thu Dec 14, 2017 9:23 am
Hi there,
The fisrt nut which is pressing the olive on the union has been found at automec, the link is here :
https://www.automec.co.uk/products/bras ... -5-16-pipe
Thank you Mgcjag for this link supplied.
Clearly, the 9/16'' with 24 threads is not easy to find. After several contact through France, UK and US, I finally founf what I was looking for.
For the one which is maintaining the union on the crossmember underneath the car, it has been harder.
I finally found someone very very helpfull!
Dean Kothmann from fitting connection does have a complete bulkhead union with the good dimentions.
He decided to send my free of charge the nut I was lookin for. Once again thak you Dean!
https://www.fittingconnection.com/
I've received by regular mail the nut:
https://1drv.ms/i/s!ArnI21033ntTils6dijMoenrAbYK
I'm now able to close the fuel line and go ahead on this topic.
I still dont understand why the current E Type parts suppliers do not have the underneath car fuel lines available. Am I the only one to face problem to get this kind of part ?
