"...remove bolts securing propeller shaft..."
jagwit
#21 Re: "...remove bolts securing propeller shaft..."
Post by jagwit » Tue Feb 27, 2018 4:48 pm
S3 parts manual shows bolt heads at gearbox end facing the front of the car. No bolts are shown for the diff end.
Best Regards
Philip
angelw
#22 Re: "...remove bolts securing propeller shaft..."
Post by angelw » Wed Feb 28, 2018 9:43 am
Hello Phillip,
In the S3 Workshop Manual, it actually makes reference to replacing the bolts in the Gearbox Companion Flange before tapping it home on the spline. No such reference is made for the Differential Companion Flange, nor for the Gearbox Companion Flange for S1 and S2 cars. In these cases it merely states to undo the nuts and recover the bolts during dismantling.
I note that Nigel's transmission is an Automatic. In this case there is no issue with replacing damaged bolts without removing the Transmission Companion Flange, irrespective of direction the head of the bolts face.
Bob.
#23 Re: "...remove bolts securing propeller shaft..."
Post by Bob. » Thu Mar 01, 2018 3:58 pm
S3 parts manual confirms that Bill.
Important to realign the splines of the two parts exactly as they were originally on reassembly, otherwise propshaft likely be out of balance.
Bob
'71 S3
Rustyred
#24 Re: "...remove bolts securing propeller shaft..."
Post by Rustyred » Sun Mar 04, 2018 11:07 am
generally the head of the bolt will be keyed by the rim on the flange allowing the lock-nut to do its job properly, so it doesn't come loose in service.
Restoring 73 Series 3 2+2
