Good Evening All
I am trying to locate a wheel clamp for my S3 2+2 V12FHC. I can find BD-36808 for the roadster, but not BD-36809 stocked anywhere
surely if the same wheel then this should fit, or am i missing something.
Appreciate your help. Last item before off to Le Mans
Steel wheel clamp FHC V12
#2 Re: Steel wheel clamp FHC V12
According to the parts manual 08 is for wire wheels, 09 is for "disc" wheels.
#3 Re: Steel wheel clamp FHC V12
Mine was also missing from my car as bought. I also could not locate the wire wheel version, and this was back in 2007. In the end I located a shorter clamp of the same design off another model Jaguar, cut in half and welded a length of bar between the handle and threaded end.
Works great.
Good luck
Kevin
Works great.
Good luck
Kevin
