Oil Filter Cartridge
Rustyred
#1 Oil Filter Cartridge
Post by Rustyred » Wed Apr 13, 2016 10:08 pm
Hello Guys.
I'm fitting the oil cartridge, and what I can't work out is the order of parts and whether I'm missing some.
The Manual doesn't show and the Exploded view on the SNG site is not very clear.
I have,
Bolt, flat washer, rubber seal, Large round formed cannister plate, cannister, spring, felt washer, dished cup then filter.
If this is the correct sequence, what seals the Cannister to Formed cannister plate and should there be a washer over the felt washer.
Or does the felt washer go between plate and cannister.
I know it's a very simple question, but not seeing one before, makes for disaster.
When I got the car, the assembly was fitted together with silicon gasket.
Regards John
Rustyred
Post by Rustyred » Tue Apr 26, 2016 3:22 am
OK, I'll ask this question a different way,
Does any sealer or gasket go between the Large dished Plate and the cannister on the oil filter Assy, If not what stops the oil leaking between the two.
Any assistance would greatly be appreciated.
Cheers John
Post by mgcjag » Tue Apr 26, 2016 7:59 am
Hi John.....sorry dont know answer to your question...but why not email Julian Barrat the boss at SNG....explain tbat tbe instructions are not clear to follow....hopefully they will give you an answer and update the info sheet
vee12eman
Kiribati
Post by vee12eman » Tue Apr 26, 2016 10:24 pm
John - PM sent.
Series III FHC
Rustyred
Post by Rustyred » Thu Apr 28, 2016 1:06 pm
Thank You for the PM Simon.
Just a question, what seals, or what do you use to seal the Cannister Plate washer to the Cannister on the Oil Filter Cannister.
Cheers John
ooi21
#6 Re: Oil Filter Cartridge
Post by ooi21 » Sat Dec 29, 2018 2:47 am
Hello Guys,
Can anyone help me in buying a filter cartridge? A few days ago, I just went to buy it. There are a lot of companies providing the same thing but at different prices, I was confused. Kindly help me with this.
#7 Re: Oil Filter Cartridge
Post by abowie » Sat Dec 29, 2018 2:59 am
If you stick to a brand name you'll get a reliable minimum quality. Otherwise it's probably just horses for courses.
lowact
#8 Re: Oil Filter Cartridge
Post by lowact » Sat Dec 29, 2018 6:09 am
Mine the rubber seal is between the canister plate and the canister. No washer under the bolt head. The washer is between the spring and the felt.
JJC
#9 Re: Oil Filter Cartridge
Post by JJC » Sat Dec 29, 2018 9:37 am
Hello: old canister style works, but a pain. At some point, might want to consider a spin on adapter. Cleaner, easy to replace. I've used it for over 20 years. Several folks offering the kit. Happy New Year !
JJ
#10 Re: Oil Filter Cartridge
Post by mgcjag » Sat Dec 29, 2018 10:17 am
Hi Guys....i think the poster(ooi21) you are replying to is a spamer......its his first post with no introduction and his ip is in India....cant see any hidden links.....lets see if he comes back.....i could be wrong....Steve
