Heating and ventilation *** Updated
JJC
#21 Re: Heating and ventilation
Post by JJC » Sat Jan 05, 2019 2:42 pm
Poor chap Martin simply want to heat the cabin of his E-Type. He was told simply how to accomplish this. But it seems some folks want to play semantics, suggest it might be something else, perhaps for no good reason then to see there words on this forum. How sad. Hot water goes up to the valve, if blocked (for the purpose of no heat), the water continues to circulate. Simple . How sad when a forum, available to help others, becomes a sounding board for self serving nonsense.
lowact
#22 Re: Heating and ventilation
Post by lowact » Sun Jan 06, 2019 6:10 am
The water thru the heater is in a parallel path to the water thru the thermostats. The pressure differential across the thermostats is what pushes water thru the heater. If you take out yr thermostats it messes up the balance, frees up the flow through the thermostat housings so more of the water takes this route, reducing flow thru the heater. Consequence is a less effective heater. All the other suggestions may be more likely however u never know. One thing I really appreciate about this forum is the passion :bigrin:
Ole-xke1974
#23 Re: Heating and ventilation
Post by Ole-xke1974 » Sun Jan 06, 2019 12:47 pm
:yeahthat: is for sure. One just have to navigate the obstacles :swerve:
Woly64
#24 Re: Heating and ventilation
Post by Woly64 » Mon Jan 07, 2019 11:07 am
I really appreciate all the input guys and the photograph in particular is very helpful. What is not helpful on my part (and probably frustrating on yours) is that I did not get chance this weekend to try out any of the suggestions so I'm afraid you are going to have to wait until next weekend for some feedback - apologies :shrug:
Martin
1971 Series 3 2+2
MTM RS6 Avant
S3 Sportsback
Polo 1.2S
1963 Vauxhall Victor Super
lowact
#25 Re: Heating and ventilation
Post by lowact » Tue Jan 08, 2019 3:26 am
WHAT??? You didn’t immediately rush out and pull yr heater apart till midnight? BH…
To test the cable to the water shut-off/reg valve (per JC): As explained. Operating the right control (Air hot-cold) needs to operate the valve full stroke.
To test the valve (per Ole, Steve): Need only drain a couple of litres out of the radiator, so you don’t spill too much coolant everywhere, anti-freeze dries to a chalky residue. Remove the two hoses from the valve, use a thin screwdriver to loosen (prise) the hoses a bit from the pipes so you can wiggle them off without excessive force. Using a short, tight-fitting hose, blow thru the valve. When the valve lever is fully CCW blowing should be easiest. If not: Valve adjustment is by a small phillips screw protruding from the back of the valve mechanism (pic).
If this is screwed too far in there is no flow thru the valve, irrespective of the lever position. If the screw is removed there is always flow thru the valve. Adjust this screw until blowing is (virtually) impossible when the lever is fully CW and isn’t easiest until the lever is fully CCW. If it is still not possible to blow thru the valve: As Steve notes, there is an auto temp control mechanism, when air temp is hot the water flow is throttled. If this mechanism is jammed (in the hot air position) u might not be able to blow easily thru the valve, even when the valve lever is fully CCW. Get a new valve.
To test the heater matrix (per Stuart, Ole): If convection makes hose temp inconclusive, alternative procedure is to remove the hoses to the matrix and try blowing thru. If cannot blow easily yr up for a new matrix.
To test the Air on/off control (per Ole): The left control (Air on-off) should flick the flap fully open or closed, no intermediate position. If the oblong vent thru the bottom of the box is open (u can stick yr hand in) it means the flap is up (vertical), air from the heater fan is being diverted into the engine bay, there can be almost no flow of heated air from the matrix into the cabin.
For hot air into the cabin this bottom vent needs to be closed by the (horizontal) flap .
Air flow over the matrix (fins) can also be blocked by build-up of dust, pollen etc. that clogs the fins. Is hard to detect this, Dismantle box and clean.
Woly64
#26 Re: Heating and ventilation
Post by Woly64 » Tue Jan 08, 2019 1:47 pm
Colin that is amazing thank you for the detailed explanation and very helpful photographs :thankyouyellow: - I now have my homework set for the weekend! Just to ensure there is no misinterpretation at my end (I'm clearly light years behind you in understanding these matters) can you confirm your meaning of the references to the control lever being CW and CCW. Thanks in advance and apologies if this is basic stuff :studyinggray:
Martin
1971 Series 3 2+2
MTM RS6 Avant
S3 Sportsback
Polo 1.2S
#27 Re: Heating and ventilation
Post by christopher storey » Tue Jan 08, 2019 2:37 pm
CW = Clockwise
CCW = Counter-clockwise = Anti-clockwise
Woly64
#28 Re: Heating and ventilation
Post by Woly64 » Thu Jan 10, 2019 5:23 pm
Got it thanks
Martin
1971 Series 3 2+2
MTM RS6 Avant
S3 Sportsback
Polo 1.2S
Woly64
#29 Re: Heating and ventilation
Post by Woly64 » Mon Mar 18, 2019 2:05 pm
Finally all sorted with the replacement of the heater matrix - now I can get warm air into the cabin just as the outside temperatures are rising!! Thanks everybody on here for your help :thankyouyellow:
Martin
1971 Series 3 2+2
MTM RS6 Avant
S3 Sportsback
Polo 1.2S
Woly64
#30 Re: Heating and ventilation
Post by Woly64 » Tue Jul 30, 2019 10:57 am
Update... gven that I had run the car for the last 12 months which was the first time it had been run consistently for 10 years I was wisely advised to also give the system a full flush through and then refilled it as quite a lot of crud had clearly been loosened by its reintroduction to the road!
All continued to run well for a few weeks with heat back into the cabin with a normally running system and then as the height of summer came along then the cooling fans packed up which is picked up in this thread http://forum.etypeuk.com/viewtopic.php?f=6&t=14428
Martin
1971 Series 3 2+2
MTM RS6 Avant
S3 Sportsback
Polo 1.2S
lowact
#31 Re: Heating and ventilation *** Updated
Post by lowact » Fri Jul 24, 2020 12:24 am
rossco_j wrote:
Tue Jul 21, 2020 8:49 am
Hello Colin / lowact,
Can you help me by clarifying your post please. I've added a marked up copy of your photo to ensure that I understand your explanation of the valve operation.
My recently re-commissioned series 3 seems to always have warm air flowing into the cabin. Not an ideal situation in Queensland...
If I'm understanding correctly, the flap in the heater box should be vertical & the valve arm towards the front of the car. I've also adjusted the philips head screw fully in.
I'm trying to achieve mostly cool air in the cabin.
Do you have a photo of your heater hose configuration please.
Thanks for your time
Yep, yr marked up pic is correct for my car, which is in pieces atm so 2 pics:
The 1st shows the engine, the upright spigot with the tape on it is for the water from the engine to the heater. The pipe with the horizontal end is for the water return, from the heater back to the engine (water pump inlet).
The 2nd photo shows the heater hoses, the centre hose pointing downwards is the heater inlet. The horizontal pipe at the bottom of the pic is the heater outlet.
However, it should not make any difference how the hoses, from the engine and to the heater matrix, connect to the valve. All the valve does is throttle the flow from the engine to the heater, it does this irrespective of the direction of the flow through the valve.
When the heater control lever (with the spring on it) is all the way forward there should be no water flow through the heater, irrespective of the position of the separate little adjusting screw at the back of the valve. You can check this by trying to blow through the valve …
The little adjusting screw, if you screw this right in, there should be no water flow through the heater, irrespective of the position of the control lever. I adjust the little screw by: starting with it initially wound out and the control lever held forward; winding the little screw in just enough to stop me blowing through the valve, this gives the largest heater operating range.
The flap in the heater diverts the air from the fan. When it is vertical this air is dumped into the engine bay, there is no air flow (hot or cold) from the heater. When it is horizontal (closed) the air from the fan flows through the heater.
Craig Balzer
#32 Re: Heating and ventilation *** Updated
Post by Craig Balzer » Mon Jul 27, 2020 5:31 am
This is way OT, but I notice you still have the oil pressure sender mounted on the side of the block (which will ultimately be hidden an made virtually inaccessible by the exhaust manifold). With your engine in this state of disassembly, it may be prudent to relocate it to inside the the V and just behind the throttle pesistal.
Craig
