Engine oil and antifreeze
Chuckp
#1 Engine oil and antifreeze
Post by Chuckp » Fri Jul 26, 2019 1:10 am
Looking for suggestions on engine oil. I’ve seen everything from diesel 15w40,15w40 synthetic blend and 15w40 std oil suggested. Various other weights also suggested. Same question for antifreeze.
Chuck
SESH
#2 Re: Engine oil and antifreeze
Post by SESH » Fri Jul 26, 2019 10:12 am
Personally I would use 20W50 Valvoline VR1 Mineral Racing Oil.
Anti Freeze would be Bluecol 2 Year (Blue). Mixed 50/50 with distilled water.
Mike
1973 Series 3 OTS Signal Red
71 V12
#3 Re: Engine oil and antifreeze
Post by 71 V12 » Fri Jul 26, 2019 2:42 pm
Mike
+1 for both suggestions
Ole-xke1974
#4 Re: Engine oil and antifreeze
Post by Ole-xke1974 » Sat Jul 27, 2019 11:57 am
I use Mobil1 full synthetic with high zinc content, but looking for a mineral oil with the same high zinc content. (sybthetic supposedly causes more oil leaks than mineral oil, so I'll give it a try)
For coolant, Evans waterless. Saved my engine on one occasion when the fans stopped working while 20 minutes in standing traffic.
Ole-xke1974
#5 Re: Engine oil and antifreeze
Post by Ole-xke1974 » Sat Jul 27, 2019 12:06 pm
Mike
Thanks for that tip !
Mephistopheles
#6 Re: Engine oil and antifreeze
Post by Mephistopheles » Sat Jul 27, 2019 5:12 pm
Dear all,
Jaguar recommended several engine oils (See picture below: extract from E Type V 12 workshop manual). Duckham Classic Q20W-50 is still available and it contains zinc based additives (might be of interest for Ole). My E Type engine is filled with Castrol Classic XL 20W-50.
I use silicate based anti freeze Glysantin G48, 50% diluted with distilled water.
Best regards
Holger
1973 manual LHD OTS E Type
Holger
