Recalibrating the Speedo
Topic author - Posts: 50
#1 Recalibrating the Speedo
ive gone from 3.54 to 2.88 , a drop of 19% to 0.81 , so is there a choice of Different Speedo Drives ? , Whats the Way Forward Guys ? , ta Russ
#2 Re: Recalibrating the Speedo
Speak to Speedograph Richfield who will recalibrate the Speedo for you and give the unit an overhaul
#3 Re: Recalibrating the Speedo
Hi Russ....the way forward is to have your speedo recalibrated as Geoff mentions above..changeing the speedo drive is not an option......Steve
#4 Re: Recalibrating the Speedo
Well it sort of is given that you can buy geared correction boxes that connect to the speedo drive and correct for diff changes, but I agree that the only sensible thing to do is get SR to overhaul the existing unit and put in the proper gears. This ensures the odometer remains correct too.
#5 Re: Recalibrating the Speedo
Here are instructions for recalibrating Smiths speedo and odometer ...
https://1drv.ms/b/s!AiSPBKa26IcchM5cQkn ... A?e=fQijSw
#7 Re: Recalibrating the Speedo
Speedo repairs and refacing.
Try this guy :
FLANNERY SPEEDOMETER REPAIR
Www.magnetic-speedometer-repair.com
He’s good and does a great job with “proper” clocks as well.
Peter.
Try this guy :
Peter.
Peter {XKE V12HE efi}
XKRS
RR Phantom 3 1937 Sedanca de Ville.
XKRS
#8 Re: Recalibrating the Speedo
Thanks for the advise , I Went for Speedograph Richfield , 10day Turnaround , Nice Job , I Checked their Work with a Fancy GPS afterwards , i was 1mph out at 70mph if That , Very Happy to Recommend them . Russ
