Strange noise
driver
#1 Strange noise
Post by driver » Sun Dec 08, 2019 6:06 pm
Hi Rob Gill here ,
the engine on my v12 seems to run well (good oil pressure no noises etc ).
BUT ,I HAVE ALWAYS BEEN AWARE OF SLIGHT TINNY /METALIC NOISEJUST OCASIONALLY ON THE ENGINE OVER RUN FROM LOW REVS ,I VERY RARELY GO OVER 2500/3000 RPM.HAVE CHECKED ALL THE USUAL MOVING PARTS AND HEAT SHEILDS ETC.THE TIMING CHAIN GIVES OFF NO NOISE ON TICK OVER OR ON NORMAL RUNNING.I AM WONDERING IF IT COULD BE A WORN TENSIONER OR GUIDE …..ANY THOUGHTS OR IDEAS ON THIS ONE GENTS.
THANKS IN ANTICIPATION
ROB :scratchheadyellow:
v12 etype 2+2
Ole-xke1974
#2 Re: Strange noise
Post by Ole-xke1974 » Tue Dec 10, 2019 1:53 am
Rob,
what do you mean by overrun from low revs ?
I'd expect a tinny or knocking noise under acceleration if you have one or more of these:
  • Lean fuel mixture
    Incorrect ignition timing
    Wrong type of spark plug
    Poor quality gasoline
Cheers ........ Ole
ManniB
#3 Re: Strange noise
Post by ManniB » Tue Dec 10, 2019 11:16 am
Rob,
don't forget to check your exhaust manifolds for a leak. It can sound much like what you describe.
- Manfred
1972 E type 2+2 Willow Green
MLBS3V12
#4 Re: Strange noise
Post by MLBS3V12 » Wed Dec 11, 2019 4:42 am
Maybe this is because the spring below is nt there:
Le chemin sera long!...
Ole-xke1974
#5 Re: Strange noise
Post by Ole-xke1974 » Fri Dec 13, 2019 1:37 pm
Good call I
Certainly a possible reason I didn't think about.
That spring is there to prevent the SS shield from rattling.
