Wind Deflectors
Topic author - Posts: 14
#1 Wind Deflectors
Hello
Has anyone had any experience installing a wind deflector on a series 3 Roadster. I note a couple of companies offer them and that they are relatively cheap. Any views please.
#2 Re: Wind Deflectors
Hi i fitted one on my s3 3 years ago its a good idea stops a lot of the buffeting n keeps her indoors happy doesn't blow her hair about as much doesn't bother me as i am eggshell blonde seriously i fitted it to stop exhaust fumes vortex back into car which it does makes driving far more pleasurable only problem i have is bolts come loose holding it up i have now locktighted them seems to have cured it
#3 Re: Wind Deflectors
Many thanks for the prompt message. Sounds very promising as an add on to the car. Do you remember where you sourced your deflector from.
#4 Re: Wind Deflectors
I have this one on my S2. It came from the UK, from a gent on this forum - can’t recall his name, though.
Has a nice LED stop light built in. I changed the mounting to connect directly to the folding top, so it would likely work on your car if you did the same.
- Attachments
- 28789DF4-9AF5-4BCD-AD9B-005DA19CD90F.jpeg (29.15 KiB) Viewed 901 times
Bob t
LHD '69 OTS. (Former) basket case
#6 Re: Wind Deflectors
Hi company is called just roadster at doncaster i colected mine as im not far away but they do mail order
#9 Re: Wind Deflectors
I brought a deflector for my series 3 from classic additions at one of the shows. It seams to be a standard deflector but with brackets for the e-type that needed to be bolted into the hard top mountings but I found a couple of issues. the hardtop bolts are coned to a degree so did not hold the deflector very well at all even with a number of washers, changing the hem to bolts helped but the deflector was to far forward for my seat position. I ended up making some modifications to the brackets to move it as far back as possible, just touching the hold frame.
The minimal testing I have done it makes a large difference to the wind in the cabin although it has not been given a full test by the wife.
#10 Re: Wind Deflectors
Probably from Dave Kerr. I have one of his on my Series 1 and I wouldn't even consider taking a road trip without it. HUGE improvement WRT wind buffeting.
#11 Re: Wind Deflectors
Mark Gordon wrote: ↑Wed Jul 01, 2020 1:02 pmProbably from Dave Kerr. I have one of his on my Series 1 and I wouldn't even consider taking a road trip without it. HUGE improvement WRT wind buffeting.
That is indeed the guy. It is a nice piece.
Bob t
