Webers or Fuel Injection
antseries3etype
#1 Webers or Fuel Injection
Post by antseries3etype » Tue Sep 15, 2020 4:56 pm
Considering some engine upgrades over the winter months and wondered if anyone had any thoughts on either adding two sets of triple Webers or an injection System to improve performance and reliability.
#2 Re: Webers or Fuel Injection
Post by christopher storey » Tue Sep 15, 2020 5:47 pm
12 chokes on 6 Webers, presumably IVA or the like, will ensure that I will be able to hear you coming from my house in Cheshire ! And if you need more performance than you have got, then I fear that you have the wrong car, because there is still ( despite the recent horsepower race ) virtually nothing to touch an E, whether 6 or 12 cylinders , for mid range performance, and on today's congested roads any more performance really is rather academic . I don't know what you are used to, but when I had a road car that would do 0-100mph in 8.5 seconds, the performance was completely unusable because it frightened people stupid as you overtook them. I don't want to dampen your enthusiasm, but I would advise that you concentrate on getting the best out of your present setup, or, if you really must make a change, go for 4 SUs
#3 Re: Webers or Fuel Injection
Post by mgcjag » Tue Sep 15, 2020 6:01 pm
If your really intetested then rearch online for Building the Legend...
jagwit
#4 Re: Webers or Fuel Injection
Post by jagwit » Tue Sep 15, 2020 6:58 pm
To improve reliability, only 1 thing is needed: upgrade the ignition to something modern like Lumenition etc.
To improve performance, serious head and bottom end work is needed before you start spending money on carbs/efi.
I converted an ex-E S3 OTS to HE using 11:1 pistons, std HE heads, Lightweight flywheel and standard V12 HE EFI hardware although managed with Megasquirt. This car ran level with a 4.2L Supercharged XK....BUT....
It was seriously frustrating not having a deep overdrive and I constantly longed for another gear or two.
After all that,I concluded that the car is much more in need of an overdrive transmission than more power.
Best Regards
Philip
antseries3etype
#5 Re: Webers or Fuel Injection
Post by antseries3etype » Tue Sep 15, 2020 7:35 pm
Thank you so much for the very informed comments. Regards
#6 Re: Webers or Fuel Injection
Post by abowie » Tue Sep 15, 2020 9:18 pm
I have 6 IDA Webers on my XJS race car. Looks cool. But you have to remove them all to replace the spark plugs. And setting them up correctly took many hours on the dyno.
Webers will not offer any added reliability over Strombergs. And they are known for causing engine bay fires in V12s.
As above, the original Opus ignition system is a frequent cause of unreliability. It is by no means my area of expertise so others might comment on the best path to improvements there.
Having said this, were you considering moving to injection you might consider adopting a modern controller that provides programmable ignition as well. This is complex, but offers many potential advantages for getting the most out of your V12. I will probably head down this route with my XJS at some point.
Jiminsd
#7 Re: Webers or Fuel Injection
Post by Jiminsd » Sun Oct 11, 2020 12:10 am
I’m not an expert, but I wanted to go with the Weber kit, but I was basically told by several restoration shops that it is almost cosmetic as the velocity stacks needed would not clear the bonnet so the short ones that come with the V12 kit are fussy and not much gain. I went with EFI.
#8 Re: Webers or Fuel Injection
Post by abowie » Sun Oct 11, 2020 4:15 am
Can you describe the EFI set up you chose? Some pics would be good too if that's possible.
Woolfi
#9 Re: Webers or Fuel Injection
Post by Woolfi » Mon Oct 12, 2020 10:03 am
I am driving a Series III since 20 years.
If you want to improve the power output an the reliability, make these changes:
1. Don't do EFI. It is a long way, until it will work good. Marek has done it. His motor is running very good But Marek is intelligent, has a lot of knowledge and experience. 99% of all car-mechanics will be "lower".
2. Don't do Weber. I spoke with two person about this. One war the owner of a workshop, who sold AND mounted these kits to Car owners. He said t me at the Essen Oldtimer Fair: Don't try Weber carbs, They are not working well on the EV12.
Roger Bywater told a German workshop owner, that the velocity stacks you need for the carbs have to be MUUUUUCH longer, than you can mount under the bonnet. For a proper working in the range of 3500 und 5500 rpm, you need relatively long stacks. For a Lamborghini of Ferrari, which are revving up to 8000rpm, the trumpets can be shorter.
3. I have 4 Stromberg on my 6,0L HE-Motor. they are working very good, the motor has a lot of power. I have done two races against EV12 with EFI. Compared against a 5,3er with EFI ( my motor had also 5,3 in the past) and a 6 L with EFI, my motor with the Stromberg had MUCH more power in the rv range of 2000 - 4000 rpm. Above this, the EFI cars have been stronger.
4. If you remove the small (32mm inner diameter) trumpets to the air-filter boxes and add straight pipes with minimum 45 mm inner diameter, the motor will produce some ponies more.
5. If you make a whole of 45 mm inside the front silencers , that the will become straight through, this will also gain some ponies.
Both changes Nr. 4 und Nr. 5 will make the motor roundabout 20 - 25 hp stronger . The sound will also become a little bit more sporty.
BUT YOU NEED TO PRODUCE 4 DIFFERENT CARB NEEDLES, that the mixture will be okay. If not, the mixture will become MUCH to lean and the motor will work very bad in the upper range.
6. These needles I have produced by myself. You need equipment, experience and knowledge. 99% of the car mechanics can't help you with this work.
7. If you change to 4 SU HD8 carbs, you can BUY needles, which fit better for the motor with the higher breathing ability. But you must know, which to select. This is also a problem for every car mechanic, who has never done this SUCCESSFULLY.
8 . To change the ignition system from OPS to a modern system from Barratt, will rise the reliability.
I am driving this car since 20 years. I have some experience with rising the hp, WITHOUT big cost. I am very satisfied with the power of my motor. Also the gas consumption is low, because of the "long" Getrag and the "long" axle. If I am driving with 100 mph, the motor revs roundabout 3000 rpm.
I have a Getrag 5-gear box in my car and a 2,88er diff. This will make you happier, than a motor with EFi or Weber. A change to EFI is expensive. You need a man, who has done THIS before and is intelligent AND has experience. Otherwise it can become a long nightmare. A lot of people are telling you, that EFI is the best . They are correct, IF (!!!) the development of the motor plus EFI has been done from a big amount of car engineers NOT car mechanics. Otherwise the time of "debugging" will last long. One friend of me has done this. Three workshops worked on this project. It took roundabout 25000 Euro (!!!) and some years, until her was satisfied.
Or ask Marek how much you have to pay to him, if he is doing the conversion for you. You need somebody who has done this before Successfully ! ! ! "Doing with the mouth" will be not enough.
Excuse my poor English!
Regards Wolfgang Gatza
jagwit
#10 Re: Webers or Fuel Injection
Post by jagwit » Mon Oct 12, 2020 10:52 am
I agree. For the money and effort, rather do a 5-speed with overdrive 5th or in the very least a 2.88 diff.
I agree! The Strommies are excellent carbs, SU's too. The Strommies are just, to me, a more elegant, better designed carb.
8 . To change the ignition system from OPUS to a modern system.
I agree. Cut and paste the dual coil ignition system from an XJS or LUMENITION or Petronix (using Ignitor-2 !!) Add the JLM519 vacuum advance module if not already fitted for highly preceptible benefits when driving normally.
I have a Getrag 5sp-gear box in my car and a 2,88er diff. This will make you happier, than a motor with EFi or Weber.
I agree, in respect of going for an overdrive transmission or the 2.88 diff. A 5-sp gearbox is not necessarily an overdrive transmission. I am leaning towards fitting a GM 700R4 to my S3. Just not sure how much body mods will be required - yet.
Best Regards
Philip
Woolfi
#11 Re: Webers or Fuel Injection
Post by Woolfi » Mon Oct 12, 2020 2:58 pm
I have mounted the Getrag 265 with 5 gears. The fifth is 1: 0,81, therefore an "overdrive".
Regrds Wolfgang Gatza
Jiminsd
#12 Re: Webers or Fuel Injection
Post by Jiminsd » Mon Oct 12, 2020 9:37 pm
My car is “in progress” so I can’t tell you the results yet. Sports Car Classics about 40 miles north of Los Angeles has been doing this for years. They have several levels of upgrades. The owner used to be some part of E-TYPE UK when he lived in the UK. As with any restoration, the budget went over rather quickly once we pulled all the junk off the top and saw some coolant that escaped one cylinder....which lead to the heads coming off..., which were fused to the steel studs, which found some scoring in 3 cylinders...you know how it goes.
The goal was to have something fun but drivable. I wouldn’t resto-mod a series 1 or 2 car, but I’m a bigger guy with a bad back and I appreciate the extra 9 inches of the Series 3 and the slight extra width. My dad had a Series 3 and a XJ12C growing up. I just retired and I wanted to make a Series 3 a bit more sporty and a bit less GT. My car will have 6.1L forged pistons, slightly more aggressive cams, ported heads, new valves, full EFI with all new electronics and aj6 (the company) exhaust, lightweight Fosseway starter and alternator along with Fosseway’s 6 piston calipers and all new brakes with 16” x 6” 205/65 Dayton wheels.
I have not decided on the 2.88 diff vs a 5 speed vs an overdrive. The car was stuck waiting on parts as it was started in January, pre-Covid, and everything got delayed. The pistons are licensed in the UK but made in California so for some bizarre reason they must go from California to the UK and back. The car just needs the pistons which should be in LA next week and then re-assembly. Hopefully, by November.
SCC just has a new website. Here is a link, though I am not going with the Jenvey EFI, but rather a proprietary one from SCC which is very similar to aJ6’s modified 6L XJS system. I can’t figure out how to upload the pictures but you can scroll through and see the “XJS” looking EFI pictures.
https://www.sportscarclassics.us/classi ... n-systems/
