Clutch master cylinder spacer
Curtis Bay
#1 Clutch master cylinder spacer
Post by Curtis Bay » Sun Nov 08, 2020 8:30 pm
I am converting a series 3 V12 auto to manual and need to install a master cylinder on the existing pedal box.
I believe there is a spacer which is fitted between the cylinder and mounting but this is no longer available. Does anyone know how thick it is is that I can make one?
I know this subject has been raised before but rather inconclusively.
1965 Series 1 4.2 FHC - Opalescent silver blue metallic with grey interior
1974 Series 3 5.3 Auto DHC - Sable with biscuit interior - something which has to change!
lowact
#2 Re: Clutch master cylinder spacer
Post by lowact » Tue Nov 10, 2020 1:45 am
My C31725 is 10.5 mm thick.
Curtis Bay
#3 Re: Clutch master cylinder spacer
Post by Curtis Bay » Tue Nov 10, 2020 8:58 am
Hello Colin
That's brilliant.
Many thanks.
madjack4
#4 Re: Clutch master cylinder spacer
Post by madjack4 » Tue Nov 10, 2020 7:25 pm
Burlins do a spacer offset for when SU carb conversion is fitted order one off them save u making one it just mounts master cylinder at slightly different angle
Regard Rob
