I am converting a series 3 V12 auto to manual and need to install a master cylinder on the existing pedal box.
I believe there is a spacer which is fitted between the cylinder and mounting but this is no longer available. Does anyone know how thick it is is that I can make one?
I know this subject has been raised before but rather inconclusively.
Clutch master cylinder spacer
Topic author - Posts: 72
#1 Clutch master cylinder spacer
1965 Series 1 4.2 FHC - Opalescent silver blue metallic with grey interior
1974 Series 3 5.3 Auto DHC - Sable with biscuit interior - something which has to change!
#2 Re: Clutch master cylinder spacer
My C31725 is 10.5 mm thick.
#3 Re: Clutch master cylinder spacer
Hello Colin
That's brilliant.
Many thanks.
That's brilliant.
Many thanks.
#4 Re: Clutch master cylinder spacer
Burlins do a spacer offset for when SU carb conversion is fitted order one off them save u making one it just mounts master cylinder at slightly different angle
Regard Rob
Regard Rob
Rob 1972 s3 roadster
Aston Martin DB9 Volante
#5 Re: Clutch master cylinder spacer
Hi. Having some clutcproblems I saw this thread. Maybe late but came across a reproduction spacer plate from scparts:
https://www.scparts.co.uk/sc_en/spacer- ... 17755.html
My problem: Master cylinder pushrod dislocated. Tried to push clutch pedal it was stuck, pushing harder it suddenly floored with no resistance. Discowered pushrod is dangling from clutch pedal arm and bent ( probably from « pushing harder» ). Have not looked more into it right now, but anyone any ideas?
Rgds Harald
Rgds Harald
