Wiring
Pete G
#1 Wiring
Post by Pete G » Sat Nov 14, 2020 11:36 am
Hanging loose from the ignition switch is a short length (about 3 ins.) of purple and black(PB) cable with a bullet snap connector on the end into which there is a short length of black cable connected. There is what looks to have been a ring terminal on the end of the black cable. This does not look like a PO addition.
The wiring diagram shows a PB cable going to earth from the horn relay via the horn push but the horns work without my cable being connected to earth.
Has anyone got any ideas what this cabling is for? The car is 1971 British spec. RHD manual, no electric aerial, no aircon, no buzzers etc.
Pete G(formally e-bygum)
1971 S3 2+2 OSB
#2 Re: Wiring
Post by MarekH » Sat Nov 14, 2020 1:36 pm
The seat belt warning system checks to see whether a key is in the ignition by providing a path to earth when an ignition key is inserted. (It then also checks to see whether someone is sitting in the driver and/or passenger seats and acts accordingly.)
Pete G
#3 Re: Wiring
Post by Pete G » Sat Nov 14, 2020 7:15 pm
Thanks for that Marek. I do not have a Seat Belt Warning System so I will ignore the cables and tie them back out ofthe way.
1971 S3 2+2 OSB
lowact
#4 Re: Wiring
Post by lowact » Sun Nov 15, 2020 11:39 am
I like this wiring diag, can't remember where I found it ...
https://1drv.ms/b/s!AiSPBKa26IcchNwTfxO ... w?e=FhbOMf
