Hi All I have a 1991 low milage xj12 engine/gearbox ECU and a series 3 e type can anybody tell me if this engine will fit without a e type sump and what other mods I will need to make. I have never had a engine for this car to exchange parts from one engine to the other. On the plus side I do have CNC milling machines and lathes to make parts if necessary. Any help and advice would be much appreciated.
Thank you
xj12 engine swop
#2 Re: xj12 engine swop
No it won't fit. If you get yourself the Feb 1974 Parts Manual for the s3 etype, then you'll see that you need to change everything t do with oil, water and exhaust to make it fit. This topic has been covered before so the information is in the archives.
I have a spare s3 v12 etype engine complete and many spare parts if you nare interested.
#3 Re: xj12 engine swop
Hi Marek. Thanks for your reply, do you have the parts to make this engine fit and if so.how much. I'm also looking for a rear seat base for a S£ 2+2 if you have one I have two XJS carb engines if anything is any good for my conversion.
