#1 Hood stowage cover fixtures
Posted: Fri Mar 25, 2016 10:38 am
by coalboy
How does the hood stowage cover on the S3 ots attach to the rear metal work. The one which came with the car has press studs but I have none on the rear deck of the car. The parts catalogue also shows nothing. At a bit of a loss.
Photos would help if possible
Nigel
Posted: Fri Mar 25, 2016 11:16 am
by MarekH
Where the trailing edge of the mohair/canvas hood attaches to the back of the car, it is done so using screws pressed through snap-fit connectors. These are neatly hidden normally because the trailing flap of the canvas top along the back of the bodywork naturally folds over the studs.
To fit the little hood cover, you fold the trailing edge of the top forward to reveal the press studs along the trailing edge. These are supplemented at each side by an additional stud attached to the velcro.
Posted: Fri Mar 25, 2016 11:26 am
by coalboy
Thanks for that. Seems to be missing the stud near the Velcro. Will look later under the rear trailing end so it is part of the hood?
Posted: Sat Mar 26, 2016 5:58 pm
by coalboy
Had a more detailed look and no press studs the Velcro is held on with very small screws so assume one press stud goes at the bottom are the others rivetted or screwed in ? If screwed do they go where the panhard screws are as well?
Cheers Nigel
