7x15 ET3 Dayton wire wheels
carlv12
Spain
#1 7x15 ET3 Dayton wire wheels
Post by carlv12 » Sun Apr 03, 2016 10:39 am
Hello,
I would like to know who has fitted Dayton wire wheels 7x15 ET3 (=with deep dish) on his E-Type V12.
I ask, because I already have fitted Dayton wire wheels 8x16 ET22 with 225/60 R16 tires and I only had to modify the rear bump stop rubbers, but with 7x15 ET3 and 215/70 R15 the rear arches must be modified, because there is not enough clearance.
Thank you and best regards from sunny Valencia
Carlos
lundabo
Post by lundabo » Tue Jun 14, 2016 6:02 pm
Hi Carlos, I don't have your answer, but am curious about the wheels you currently have on your car. Do you have a spec sheet or something that can be used to order them from Dayton, or someone else that makes wheels to order. If they work on your car with minor modification to the bump stops, that prevents having to recreate the wheel (so to speak). Thanks, in advance.
