Radiator fan relay: where is it located?
#1 Radiator fan relay: where is it located?
I have not searched for it yet, perhaps someone knows where it is?
Best Regards
Philip
Jag: 72 E-type V12, 80 XJS (Megasquirt + 5sp manual O/D)
Philip
#2 Re: Radiator fan relay: where is it located?
It is on top of the rhs of the radiator. If you have aircon, then the aircon relay is to its left. If your car has a shroud fitted, then that'll be why you can't see them.
#3 Re: Radiator fan relay: where is it located?
I was considering upgrading the 12V supply to the fan relay but I've now concluded that the standard wiring (in this instance) can hardly be improved upon.
Best Regards
Philip
Philip
