Another Restoration of a 1963 3.8l FHC
Members cars waiting to be restored, being restored or fully restored.
Polse7317
#1 Another Restoration of a 1963 3.8l FHC
Post by Polse7317 » Thu Jul 09, 2015 9:11 pm
Hello Etype lovers, here is the adress about my "job" on a wonderful long nose ! Y am not a Professional but y try to be the most close to the original model.
Enjoy my blog and post some comments , y wait for them with pleasure.
http://forums.motorlegend.com/vb/showthread.php?t=42659
ralphr1780
Post by ralphr1780 » Fri Jul 10, 2015 7:36 am
Barvo Lataud!
With excellent humor all along!
Ralph
'69 OTS + '62 OTS - Belgium
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 11:37 am
Thanks a lot :wink:
Quattrofrank
Norway
#4
Post by Quattrofrank » Fri Jul 10, 2015 11:51 am
Wish I could understand french.
But nice pictures, do you have some more showing the rubber around door frame and b pillar? I`m in the process of changing mine but i dont think there is the right one there at the moment so no use in copying what is on the car at the moment
Post by Heuer » Fri Jul 10, 2015 12:22 pm
Excellent bog Yves!
For non-French speakers Google Chrome should automatically translate the entire page. If not, go to 'settings' 'advanced' and scroll down to 'Languages'. Check 'Offer to translate pages .....' You should also be able to right mouse click on a foreign language page and ask it to 'Translate to English'.
S1 OTS OSB; S1 FHC ODB
Pin your E-Type to our World Map: https://www.zeemaps.com/map?group=184509
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 12:27 pm
I'll post some pics tomorrow, I can't post them at this time ... :?
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 12:30 pm
Just a question for HEUER, how can I switch my name in the post title ( LATAUD is my first one ) by my second which is : Yves ?
Post by Heuer » Fri Jul 10, 2015 2:18 pm
You can't. Only way to change is to set up a new account. You can put your second name in your signature, which I see you have already done. You could edit your signature an put both names in to avoid confusion.
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 2:21 pm
Yhad as you some questions about fitting all these seals....Y fit at the end the complete Apost seal from the bottom front door until the rear top angle of the window frame just close to yhe rear window pillar
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 2:23 pm
don't keep in memory all the remarqs about the pictures , they are not right now :?
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 2:42 pm
The problem now is to shut completely the door with the compression of the new seals which are very stiff .
ralphr1780
Post by ralphr1780 » Fri Jul 10, 2015 3:15 pm
Yves, when I first fitted the doors and trunk seals on my S2 it was indeed difficult to close the doors and trunk.
I have used some silicone spray applied on a towel then wiped over the seals and the doors/trunk where they meet the seals. This has improved things a lot because the seals would then slide a bit easier when compressed.
With time (few weeks to few months), the seals will the final shape and no more difficulty to close the doors and trunk.
Il faut laisser faire le temps!
Ralph
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 4:09 pm
well done, that's what y 'll do on my seals too.
thank's tricky raphr :wink:
Polse7317
Post by Polse7317 » Fri Jul 10, 2015 8:54 pm
Here are some photos of the door seals as they are fitted on my car
Polse7317
Post by Polse7317 » Wed Jul 15, 2015 9:03 pm
these last two days were occupied with the rear axle....
It was a hard job to fix the silent-blocs with their thickness shims on the body .
At the beginning it was that:
After a few hours of work.....with a tricky job to put the two shafts at the right place with all the washers in the middle
It is ready to come back on the car !
When your son has taken the ladder out, you have to be ingenious....! to put the rear axle on its Rolling trolley
And now I can fix it on the car .....!
And now I have to fit the hand brake and all the propeller shaft, it must be an easy job I hope !
Post by MarekH » Thu Jul 16, 2015 7:13 am
Dear Lataud,
It'll be very easy if you take the engine or IRS back out of the car first.
Post by christopher storey » Thu Jul 16, 2015 8:57 am
Marek : you need new glasses ! The prop shaft is already present in the tunnel, as can be seen in the photos
Post by MarekH » Thu Jul 16, 2015 9:59 am
That's a lucky break then. Lataud would need a new sense of humour if it weren't!
Polse7317
Post by Polse7317 » Thu Jul 23, 2015 8:00 pm
of course y spoke about the front end of the propeller shaft.....
Polse7317
Post by Polse7317 » Fri Jul 31, 2015 6:42 am
My job now is concentrated around the bonnet.... 3 years ago it was that :Image
The precedent owner had taken off all the chrome beads and weld the wings to the central panel.....So y cut all the weld points and tried to keep the wings with all the metal "blades"
Now y fix the different parts together... trying to get the right curve line beetween the parts. But the problem is that there are some "gaps" beetween the central panel and the diaphragms and valances (1) on the last pic
Image?id=23384389c2.jpg]Image[/URL]
