Another Restoration of a 1963 3.8l FHC
Members cars waiting to be restored, being restored or fully restored.
Polse7317
Post by Polse7317 » Sun Feb 14, 2016 7:43 pm
I have changed the bonnet wiring loom as it was free between the two sides of the bonnet ( i saw this on the dave66jaguar blog )
With a rubber protection
ralphr1780
Post by ralphr1780 » Mon Feb 15, 2016 9:48 am
Yves, missing the air duct panel (BD16557) or you will fit it later?
Ralph
'69 OTS + '62 OTS - Belgium
Polse7317
Post by Polse7317 » Mon Feb 15, 2016 11:12 am
I'll fit it after ..... I can't take the picture with !
Polse7317
Post by Polse7317 » Sun Feb 28, 2016 6:25 pm
I worked on the windscreen last week : rubber around the glass , a thin string in the groove , two "suction grip handles" , putting the rubber in the bottom location and then turning around the corners starting along the bulkhead to finish in the middle of the top :
Insert the middle rubber string,
After the challenge is to fit the upper chrom , i have to bend it slowly...... very slowly ..... and it fits .... ImageImage
Another challenge is to stick the lateral chroms at the right place but i have to do the job with the lower chrom which is more difficult to adjust .
when it is bended, the upper edge can't be fitted Under the rubber lip .
I don't know how to do the two curvatures , when i bend in one direction it opens the upper edge and when i begin to curve the upper edge, it opens the first curve.....
If somebady has the solution, my ears are completely opened :)
265bhp
Post by 265bhp » Sun Feb 28, 2016 7:02 pm
Hello Yves
Are these original chrome parts or new reproduction ones.?
Jonathan
1963 3.8 FHC in slow restoration mode
Polse7317
Post by Polse7317 » Sun Feb 28, 2016 7:38 pm
they are reproduction parts ..... !!! so .... the shape is not correct
265bhp
Post by 265bhp » Sun Feb 28, 2016 10:32 pm
Hello Yves
Not sure if this will solve the issue, and maybe you have already looked through the excellent restoration story from Chris....
viewtopic.php?t=1752&postdays=0&postorder=asc&start=300
Have a look at page 31..perhaps there might be some help there..?
Jonathan
Polse7317
Post by Polse7317 » Mon Mar 21, 2016 10:54 am
This WE i have finished the windscreen chromes fitting....! with 6 magic tools : the windscreen suction press :
the most difficult in the process is to have the right curve with the chromes blades
Polse7317
Post by Polse7317 » Mon Mar 28, 2016 9:27 pm
I am now on the rear seat panel, and i Wonder how is that panel covered on its back side ? I have only the front cover knowledge, with Vinyl ...i suppose the back side is the same ?
I continue trimming Inside :
Polse7317
Post by Polse7317 » Sun Apr 10, 2016 7:44 am
Always working on the cantrails....
at the beginning:
Iwas worry about refitting the chrome bead , but with calm and a protected pliers, i am quite glad about the result
At the end ... i have "only" to fix them Inside ....
By the way i have also fitted a new coolcat fan
Polse7317
Post by Polse7317 » Sun Apr 24, 2016 8:00 pm
I continue fitting the cantrails with again problems to match the position of the cantrail and the door aperture
But with time , the result seems +- correct:
After the cantrails, i continue with the cross member and the central console
Polse7317
Post by Polse7317 » Sun May 29, 2016 5:52 pm
Continuation of trimming around the cantrails :
Polse7317
Post by Polse7317 » Mon Jun 06, 2016 11:17 am
Trimming the sills and the Under Windows parts:
Glue side by side , to fix the position, of the foam and after the vinyl
Sometimes a little seringue is helpfull for close location of the edge of the sill vinyl
Modification of the shape of the cardboard to match with the sill. I slide a thick piece of plastic to avoid scratching the vinyl
there are some wrinckles which will be modified later..... :?
frogeater
#74 Re: Another Restoration of a 1963 3.8l FHC
Post by frogeater » Sun Jul 10, 2016 6:30 pm
Indeed!!! Great work.
Will you keep the french finishing touch on the gearbox? :smile:
Emmanuel. PIR27059 in restored condition to COMPLETE Européen condition (except power steering)
Polse7317
#75 Re: Another Restoration of a 1963 3.8l FHC
Post by Polse7317 » Tue Jul 12, 2016 12:37 pm
:thankyouyellow: Emmanuel, i'll continue effectively with the gearbox after trimming the doors. But i spent last WE at LE MANS CLASSIC and i saw some E there and i saw that they were quite lower than mine for about 2 inches at the front suspension... :scratchheadyellow: so i have to change the torsion bar settings , which is a big job for me :roll:
#76 Re: Another Restoration of a 1963 3.8l FHC
Post by christopher storey » Wed Jul 13, 2016 9:10 am
If you have not driven your car yet, there is no need to adjust the torsion bars at the moment . The car will settle noticeably lower in the first 200 - 300 kms of driving
Polse7317
#77 Re: Another Restoration of a 1963 3.8l FHC
Post by Polse7317 » Wed Jul 13, 2016 2:26 pm
Even with 2 inches too high ? :scratchheadyellow:
#78 Re: Another Restoration of a 1963 3.8l FHC
Post by mgcjag » Wed Jul 13, 2016 4:52 pm
Hi Yves...did you use setting links to set the front ride height of the torsion bars
#79 Re: Another Restoration of a 1963 3.8l FHC
Post by christopher storey » Thu Jul 14, 2016 7:20 am
lataud wrote:Even with 2 inches too high ? :scratchheadyellow:
Oh yes, I do not regard 2" as much. Quite apart from the bushes settling ( and in that connection they should not be tightened up fully until the car has run a mile or two ) the front wheels take some distance to assume their proper track, which affects the ride height considerably . I should wait and see what it's like after some running on the road - and in any event, too high is infinitely preferable to too low !
Polse7317
#80 Re: Another Restoration of a 1963 3.8l FHC
Post by Polse7317 » Thu Jul 21, 2016 6:32 am
Effectively i used the setting bar preconized in the service manual, but i have fitted the TB 2 cm lower than the bar after reading a post( i don't remember which one) which said it was better to do that..... the mistake comes here ! :oops: .
