brake servo heat shield
tim wood
#1 brake servo heat shield
Post by tim wood » Sat Mar 30, 2013 10:42 pm
Hi, I have a 4.2 series 1. I believe I should have a heat shield fitted to the engine frames to deflect heat from the area of the brake servo.
This isnt fitted, am i correct in saying this should be present?
Ive looked at those offered in stainless by one of the exhaust manufacturers but they only offer a top frame shield at extortionate prices.
Assuming I need one does anyone have a good source?
all help thankfully rec'd
tim
chrisvine
Post by chrisvine » Sat Mar 30, 2013 11:14 pm
Tim,
I think the heatshield is needed to protect the servo. I was in the same dilemma and ended up fabricating my own heatshield, which isn't that difficult if you do it in aluminium. It's easy to cut and bend if not too thick, ie less than 3mm.
The original heatshield was fairly fragile but if you want dimensions then let me know.
Most heat transfer is by convection so a simple physical barrier would probably be sufficient to protect the servo. Hence why the aftermarket offerings are just metallic barriers.
Chris[/i]
1969 S2 OTS, Elise S1
Post by PeterCrespin » Sun Mar 31, 2013 2:21 am
Dave Kerr sells nice stainless ones with a modern safe asbestos-lookalike backing. There is a lot of radiant heat transfer, which increases with revs at c
at speed when convection is reduced due to air currents. Problems do tend to show up in hot slow traffic, however, especially on cars with multi-brancy headers.
ChrisC
Post by ChrisC » Sun Mar 31, 2013 6:34 am
I have just manufactured one in my last blog post tim. Easy enough to make and I can post up the dimensions if you are interested.
The shield that Pete mentions is fitted under the car between the silencer and the bodywork but I don't think that is what you are asking about.
1964 FHC 4.2
Post by PeterCrespin » Sun Mar 31, 2013 8:39 am
I was talking about the servo heat shield as per the question, not the silencer heat shield or the one alongside the gearbox.
ChrisC
Post by ChrisC » Sun Mar 31, 2013 10:14 am
Okay Fair enough but Dave doesn't make those... Hence why I ending making it. Although to be fair he did bend the SS sheet for me
1964 FHC 4.2
Post by Heuer » Sun Mar 31, 2013 10:57 am
He made mine, including insulation! SNG are now selling the original pattern plus brackets although I am not sure they have heat insulation material on them.
ChrisC
Post by ChrisC » Sun Mar 31, 2013 11:38 am
I suspect he can make anything if you ask him :D
1964 FHC 4.2
Dave K
#9 Re: brake servo heat shield
Post by Dave K » Sun Mar 31, 2013 12:49 pm
tim wood wrote:Hi, I have a 4.2 series 1. I believe I should have a heat shield fitted to the engine frames to deflect heat from the area of the brake servo.
tim
Tim,
On LHD cars there are two heat shields one to protect the bottles and one to protect the servo. On RHD cars they don't require the top shield.
The top one is angled and the bottom one a rectangle. These are the only two I know of in this area.
I can supply either backed with ceramic material that has a lot higher heat deflecting properties than asbestos. Mine are extortionate as well at ?25 each!
If you want one drop me a PM me.
Heronscourt
#10 Re: brake servo heat shield
Post by Heronscourt » Tue Sep 14, 2021 10:23 am
Hi Dave, are you still making the heat shield which fits to the frames to protect the servo. I need the shield for a RHD series 1.5 roadster complete with heat absorbent material. The car was originally LHD and I have the heat shield for that but it’s in rough state and has the original asbestos material. While on the subject of heat shields do you have a recommendation for a waterproof heat absorbent material for the under body exhaust and gearbox heat shields, preferably with a strong self adhesive backing. The original was an asbestos material which had absorbed water and was falling apart.
Alan R
Etype series 1.5 roadster 1968
#11 Re: brake servo heat shield
Post by chrisfell » Tue Sep 14, 2021 5:53 pm
No heat shield on my ‘67 2+2. Over 200,000 miles and not needed one yet.
