I wish to check the Oil Pressure on my Series 2 OTS and already have an old Smiths mechanical gauge. Would anybody know where I could obtain a pipe and fittings to connect the gauge to the car, preferably where the sender screws in?
Thank you
Mechanical Oil Pressure Gauge
Topic author - Posts: 170
#1 Mechanical Oil Pressure Gauge
Simon Brown
1998 XK8 Coupe
2008 Mazda MX-5 2.0 Icon
1991 Mini Cooper 1.3i
1998 XK8 Coupe
#2 Re: Mechanical Oil Pressure Gauge
Try M&C Wilkinson as they sell a complete kit so can also supply the fittings without the gauge.
S1 OTS OSB; S1 FHC ODB
#3 Re: Mechanical Oil Pressure Gauge
Places like Demon Tweeks sell all the fittings and adaptors you will ever need. If you are replacing the unreliable electric one then remove the sender and fit your pipe there. If you are adding it as second gauge then e.g. Demon Tweeks sell T pieces to allow both the electrical sensor and your mechanical one to be plumbed to the same take off at the oil filter housing. Just making clear I have no connection to Demon Tweeks...don't think I have ever ordered from them...
#4 Re: Mechanical Oil Pressure Gauge
In the US, try Nossinger Instruments, Mamaroneck, NY Smiths dealer. The best !! Just have to add a bit for shipping if you can't find nearby.
#5 Re: Mechanical Oil Pressure Gauge
Ordered from M and C Wilkinson
Thanks for your help
Simon Brown
1998 XK8 Coupe
1998 XK8 Coupe
#6 Re: Mechanical Oil Pressure Gauge
Check my post below......only problem will be shipping cost.
JJC
JJC
