Series 2 Import
mjp001
#1 Series 2 Import
Post by mjp001 » Mon Jun 11, 2018 11:23 am
Hello, I am new to the forum.
I am looking at purchasing a 1970 series 2 which I have just discovered is an import that has been converted to RHD. Are there any warning signs I should look for and are there any issues with purchasing a car that has been through a conversion?
Many thanks
#2 Re: Series 2 Import
Post by mgcjag » Mon Jun 11, 2018 12:18 pm
Hi Whats your name....basically there is nothing wrong with an imported car that has been converted...you have to do plenty of checking to make sure that what you think you are buying is what the car actually is..but thats the same with any purchase.....you should check to see if the details of the car are on http://www.xkedata.com a very good resource to use...or you can list more details on here like the reg no...chassis number, model, ect and members will give as much info as possible to help you.....is it a private or dealer sale.........becaus of the increasing prices of E types many have been imported and converted.....nothing wrong with that so long as its been done properly.... Steve
#3 Re: Series 2 Import
Post by Gfhug » Mon Jun 11, 2018 12:38 pm
I'll echo what Steve has said, adding you should look for an experienced E Type owner and/or restorer to have a look at the car for you. Not just someone who claims to know old cars, but truly knowledgable about Es.
Have you looked at any others to compare what you would be getting for your money?
cactusman
#4 Re: Series 2 Import
Post by cactusman » Mon Jun 11, 2018 12:53 pm
I'd echo all the above comments. The conversion is purely a mechanical exercise all be it with some trim and major mechanical bits to be replaced. The structure of the car remains the same so the same sorts of rust issues apply.
What ever the car be very sure it is legitimate. Check all the documentation you can...V5C and documentation on the conversion. Have an HPI check done. If it is an import there should be paperwork for this. As already said, check Xke data and post any info you can on here. It is almost certainly a perfectly honest car but it is worth being sure...
As far as the car goes the main issue is always rust so get someone whom knows e types to have a good go over the car. Being an import it may be good but not every import is a "rust free Californian car" so be sure it is not a rot box before parting with large amounts of cash.. Good luck and keep us posted.
mjp001
#5 Re: Series 2 Import
Post by mjp001 » Mon Jun 11, 2018 3:55 pm
Thank you all for your posts. Very useful
Martin
#6 Re: Series 2 Import
Post by politeperson » Mon Jun 11, 2018 7:22 pm
I like rust free West Coast cars. I was lucky with mine.
Fixing faults is a doddle compared to fixing rust!
Doing the LHD/RHD conversion is not to hard on an e type too. The main safety items are wiring (all visible) and steering joints.
viewtopic.php?f=1&t=9181&hilit=8+weeks
James
L.J.K. Setright was right.
#7 Re: Series 2 Import
Post by Series1 Stu » Mon Jun 11, 2018 10:00 pm
Don't forget to make sure the gauges in the instrument panel were re-arranged to the RHD format as well. Including the legend strip.
'94 X300 XJR basket case
#8 Re: Series 2 Import
Post by Gfhug » Tue Jun 12, 2018 7:35 am
Stuart, I don't think the legend strip is different on an S2 LHD vs RHD. Wasn't that just on the S1s?
duds37
#9 Re: Series 2 Import
Post by duds37 » Thu Jul 26, 2018 6:45 pm
Hi tempted by a stripped s2 fhc import,it is ideal for the rhd conversion.my q is does the Nova cert state it is lhd?...So if I register it for UK use after conversion it would state a rhd on v5c nothing else.😇
#10 Re: Series 2 Import
Post by politeperson » Thu Jul 26, 2018 8:49 pm
Duds,
It doesn't matter what it says on the Nova cert.
I filled mine out as RHD after I had done the conversion and that is how it is registered.
James
James
mach2andy
#11 Re: Series 2 Import
Post by mach2andy » Thu Jul 26, 2018 9:33 pm
The only comment I would make about this is the fact that the vendor [ a trader I'm guessing?? ] should really have disclosed this to you from the start. If they're are not being open about such a basic facet of the car, then can you really trust them ??
ATB
Andy
Andy Chalmers [in Hove]
1970 S2 FHC in pieces, but pieces flying more in formation now.
1965 SB Corvette Ragtop
duds37
#12 Re: Series 2 Import
Post by duds37 » Fri Jul 27, 2018 12:10 pm
Duds,
James
Cheers James ,now all i have to do is take the plunge.😀
#13 Re: Series 2 Import
Post by politeperson » Fri Jul 27, 2018 4:09 pm
Just go for it.
PM me the add or pics if you want and Ill have a look for you.
James
James
