Dashboard Gauge rubber seals
Topic author - Posts: 115
#1 Dashboard Gauge rubber seals
Hi gents and ladies,
Regarding my Series 1, 4.2 E-Type, DHC, somewhere I have seen advertised for sale, a set of new seals for both the inside and outside of the dashboard gauges (including speedo and rev counter) but despite searching like mad, I cannot find the ad again.
Can anybody point me in the right direction to get these seals so that I can continue the rebuild of my dash consoles?
Many thanks,
George
Many thanks,
George
1967 Series 1 OTS
#2 Re: Dashboard Gauge rubber seals
The ones that go between the outer ring and the glass are just there to stop the glass rattling around. I found some soft rubber tubing of a suitable diameter (something like 3mm iirc) in a garden center. Come to think of it, it might have been a petcare place (aquarium tubing).
#3 Re: Dashboard Gauge rubber seals
Many thanks for your response - an interesting solution! Trouble is, I also need the inner seals.
I have found a set advertised by XK Unlimited in the States but so far, nothing similar in the UK.
1967 Series 1 OTS
#4 Re: Dashboard Gauge rubber seals
Auto electrical spares.co.uk
Also have an eBay site I think
#5 Re: Dashboard Gauge rubber seals
I used this chap on eBay for replacement gauge seals, there are two types of thickness seals for the 4 X 2” and 1 X 2 1/2” gauges, I used .069 gauge o rings for these and are the same as the originals.
Regards, Julian.
https://www.ebay.co.uk/itm/JAGUAR-E-typ ... SwB09YQDIE
Regards, Julian.
#6 Re: Dashboard Gauge rubber seals
JDO Instruments repair instruments and supply instrument rubbers
http://www.jdo1.com/bezels_gaskets.html
Regards John
Regards John
1971 Series 3 FHC 2+2 RHD Manual
1971 Series 3 Roadster 2+2 RHD Manual
1986 Rover SD1 Vitesse Twin Plenum
#7 Re: Dashboard Gauge rubber seals
Try Nossinger, in Mamaroneck , NY, USA,...he is a Smiths dealer and repair shop.....one of the best. He has the rubber rings you are looking for.
#8 Re: Dashboard Gauge rubber seals
George, I used the Danbury Hydraulics kit linked in post no5 above which I suspect is the one you're trying to recall.
It's fine but I had to buy separately 3mm neoprene rubber sealing to go inside my speedo and tachometer. Very cheap and available from lots of eBay sellers.
1969 Series 2 FHC
1969 Series 2 FHC
#9 Re: Dashboard Gauge rubber seals
Danbury kit came with Neoprene seals included
#10 Re: Dashboard Gauge rubber seals
I use O-ring cored you can buy it in lots of dia. then bond it at the ends with a type of super glue.
I buy mine from Simply Bearings & they do free delivery on any orders.
Neal.
Neal.
#11 Re: Dashboard Gauge rubber seals
Got all mine from auto electrical spares in the UK.
http://www.autoelectricalspares.co.uk/b ... s-68-c.asp
-Mark
#12 Re: Dashboard Gauge rubber seals
Thinking again I used Danbury Hydraulics. They have an eBay site. Purchased a complete set of both inner and outer seals.
#13 Re: Dashboard Gauge rubber seals
Hi guys,
Many thanks for all the responses. I managed to get a full set of 13 seals from Danbury Hydraulics on ebay for £11.25 delivered. Seals were for inside and outside all six gauges plus an extra for a different dash layout - for a clock I think. Very pleased with the product and the speedy service. Highly recommended for anyone needing these new seals.
1967 Series 1 OTS
