Headlamp bezel screw thread size?
Jeremy
#1 Headlamp bezel screw thread size?
Post by Jeremy » Fri Jun 15, 2018 4:38 pm
Help please. I'm fitting the headlamp glass covers and the threads of the captive nuts in the bonnet for the chrome bezel screws need cleaning out. I can't work out what size tap I need. My thread gauge indicates it is 32 TPI. I've tried UNF 10-32 but that's too fat. Doesn't look like 2BA either (also too fat). Might it be 5/32 Whitworth?
Many thanks,
Jeremy
1967 S1 4.2 FHC
#2 Re: Headlamp bezel screw thread size?
Post by Gfhug » Fri Jun 15, 2018 5:11 pm
UNC 8-32 perhaps? Sorry can't tell you for certain, but if 10 is too fat the 8 UNC is 32 tpi.
Jeremy
#3 Re: Headlamp bezel screw thread size?
Post by Jeremy » Fri Jun 15, 2018 6:17 pm
Thanks Geoff. Anybody else know for certain?
Jeremy
1967 S1 4.2 FHC
#4 Re: Headlamp bezel screw thread size?
Post by chrisfell » Fri Jun 15, 2018 6:23 pm
5/32 x 32
Jeremy
#5 Re: Headlamp bezel screw thread size?
Post by Jeremy » Fri Jun 15, 2018 7:39 pm
Is that BSW Chris?
Jeremy
1967 S1 4.2 FHC
neal herridge
#6 Re: Headlamp bezel screw thread size?
Post by neal herridge » Mon Jun 18, 2018 5:27 pm
Hi Jeremy.
They are 8 UNC.
Neal.
#7 Re: Headlamp bezel screw thread size?
Post by Series1 Stu » Tue Jun 19, 2018 3:54 pm
There is no such thing as a 5/32 Whitworth fastener and certainly no Whitworth fasteners with 32 tpi.
BSF has a 32 tpi but that is 3/16" only. BSF are not common in automotive applications.
It certainly won't be an American thread or a metric thread so that leaves good old Unified.
Choices at 32 tpi are 6-32 UNC, 8-32 UNC & 10-32 UNF.
10-32 UNF is about 3/16" dia. 8-32UNC is a little over 5/32" dia. & 6-32 UNC is an oversize 1/8" dia.
We really shouldn't guess at sizes in an effort to assist others.
As Neal said, 8-32 UNC is the likely size but the dimensions I've just given you should enable you to decide for yourself.
'78 Land Rover Series 3 109
Julian.P
#8 Re: Headlamp bezel screw thread size?
Post by Julian.P » Tue Jun 19, 2018 6:55 pm
Thread size is 8/32 UNC.
Regards, Julian.
Jeremy
#9 Re: Headlamp bezel screw thread size?
Post by Jeremy » Tue Jun 19, 2018 7:51 pm
Many thanks all for your assistance. I will get me an 8/32 unc tap.
Jeremy
1967 S1 4.2 FHC
