Glue cantrail seals
MarkRado
Austria
#1 Glue cantrail seals
Post by MarkRado » Wed Jun 20, 2018 6:00 am
Hi all,
I am about to replace the hoodframe -to-doorglas cantrail seals on my OTS using seals from Baines. What kind of glue can you recommend? Where to glue - only the channel or also the sealing section? :scratchheadyellow:
Thank you
1963 OTS 880436
mark10337
Switzerland
#2 Re: Glue cantrail seals
Post by mark10337 » Wed Jun 20, 2018 8:20 am
Rory had good results using Loctite 5375 as per this very interesting write up he did
viewtopic.php?f=5&t=9117
-Mark
AshM
#3 Re: Glue cantrail seals
Post by AshM » Wed Jun 20, 2018 9:07 am
100% support the recommendation of using Rory’s post for reference.
Based on his feedback and write up I used two of his recommended Loctite products on my door seals replacement during the winter and have been delighted with the results.
Ash
Series 2 FHC 1970
1R 20607
MarkRado
Austria
#4 Re: Glue cantrail seals
Post by MarkRado » Thu Jun 28, 2018 11:51 am
Thank you, Ash & Mark!
I believe I still have a black super-sticky Loctite cartridge lying around - will have a look what number it has.
1963 OTS 880436
AshM
#5 Re: Glue cantrail seals
Post by AshM » Thu Jun 28, 2018 1:23 pm
Hi Mark
The 5910 product is black and super strong. It is brilliant if you want a very firm fixture and it can also be used to fill gaps. But once it’s dry then you have committed whatever you have stuck. It will destroy rubber seals if you have to take them off.
5375 not as strong, much easier to work and is clear. I have a rear hatch alignment problem at the moment and had to remove the new seals to see if that was the issue ( it wasn’t) but the seals were not damaged and could be cleaned up and reapplied.
I used 5375 for most of my seals but then small quantities of 5910 where I wanted extra adhesion or to fill small gaps. All good so far.
Ash
Series 2 FHC 1970
1R 20607
mark10337
Switzerland
#6 Re: Glue cantrail seals
Post by mark10337 » Thu Jun 28, 2018 2:12 pm
I've just used some 5375. Very pleased with it. Best results I've had so far.
-Mark
#7 Re: Glue cantrail seals
Post by rswaffie » Thu Jun 28, 2018 2:32 pm
I’ve just purchased those two products after reading Rory’s posts - looking forward to testing them out on the new seals and external trim.
:England:
