Hello, I'm new to this group, I have or I should say in the process of buying a series 2 OTS that is missing the data plate, the vin # for the car is 1R8330 and the owner states it has it's original engine, I would like to verify that fact before I move forward with this purchase, Is there any quick way that you may know off to check the number for me, Please.
Thank you. Brett
Hello & I need a bit of data.
#2 Re: Hello & I need a bit of data.
Contact Jaguar Heritage and buy a Heritage Certificate. You will need engine number, body number, car number you already have and gearbox number. JH will send you a certificate with those numbers on it with "not original" alongside any that don't match their records. I suggest you get the vendor to do that (and pay the £35 fee) telling him it will smooth the sale. Alternatively do it yourself.
As a guide the engine number should be in the 7R8XX range, body in the 4R24XX range and gearbox in the KE51XX range.
#3 Re: Hello & I need a bit of data.
I popped the vin on Xke data. Nothing popped up but it is in the range for a series two OTS in left hand drive. Make sure you see the v5C (assuming it is already registered here in Blighty) too and check what numbers that has...
#4 Re: Hello & I need a bit of data.
In principle what David ( Heuer ) has said is sound, but I think there is a mistake in his suggested engine number range, which I would expect to be 7R 3xxx if the engine is original and contemporaneous with the car . That having been said, I am always suspicious about cars without an ID plate unless there is unambiguous other information to identify the car e.g the chassis number being still stamped on the right hand upper front damper mounting, and I should warn you that registering a car in the UK these days can be tricky if its identity is in any way hard to establish . Keith Vincent of the JEC is the great expert in these matters, and it would be worth speaking to him before you buy : keith.vincent@uwclub.net or 01962 884088
#5 Re: Hello & I need a bit of data.
yes, sorry a typo on the engine number - should be 7R 38xx range.
#6 Re: Hello & I need a bit of data.
Thank you for the information, I'm still waiting for the seller to find the data plate, but the vin number in the windshield does match the number on the frame rail, (once I cleaned the built up paint of it) . I also managed to read the engine number 7R3903. so that would say, if I read the replies correctly, that it also would be a engine used in E-Types, so things looking better, but holding off final payment till that data plate is produced. Thank you everyone.
#7 Re: Hello & I need a bit of data.
Yes that is probably the correct engine for the car - the serial numbers do not follow on in sequence and 3903 is completely feasible.
