On the back of a Lucas RB340 v.r. there are three tubular items connecting metal tabs...what are these items?
Many thanks, as always
Alan
NewJersey
Control box (voltage regulator) question
#1 Control box (voltage regulator) question
- Attachments
- 0C7D7C18-95D8-407F-9408-A725AB19A31B.jpeg (41.13 KiB) Viewed 1704 times
#2 Re: Control box (voltage regulator) question
Wire wound resistors.
S1 OTS OSB; S1 FHC ODB
#3 Re: Control box (voltage regulator) question
Thanks, David.
When my RB340 failed I replaced it with another unit and all is well now.
Please look at the back of my failed unit...it appears one of the wire wound resistors has burned out. Can this be easily and cheaply repaired?
Thanks again,
Alan
Thanks again,
Alan
- Attachments
- C3526659-B679-427A-B587-96E7B93DE39C.jpeg (37.13 KiB) Viewed 1641 times
#4 Re: Control box (voltage regulator) question
Wire sound resistors.are.available from, among others, radiospares. Www.rswww.com.
