Bonnet stop
Bernie2015
#1 Bonnet stop
Post by Bernie2015 » Sat Nov 03, 2018 9:15 am
Hi All,
my bonnet need to be adjusted so the over riders on the front bumper dont hit the floor when the bonnet is fully open. Does anyone know a fix for this?
Bernie 1966 S1 OTS
Jeremy
#2 Re: Bonnet stop
Post by Jeremy » Sat Nov 03, 2018 11:26 am
Bernie, I would start by checking the car's ride height isn't too low. If you have the standard balance links fitted there really shouldn't be a problem. Has the bonnet been modified or rebuilt after a shunt? Standard bumpers/overriders correctly fitted? Can you post some pics? Bonnet shut/open, view from the side at wheel hub level, close up of balance links when open etc.
Jeremy
1967 S1 4.2 FHC
#3 Re: Bonnet stop
Post by malcolm » Sat Nov 03, 2018 11:33 am
Are you parked on the level? My overriders clear the ground, UNLESS I'm parked on a slope, then they can touch. I keep a couple of beer mats with me for such eventualities!
Bernie2015
#4 Re: Bonnet stop
Post by Bernie2015 » Sat Nov 03, 2018 1:20 pm
Thanks for the responses. The car is parked on the level and over riders are fitted correctly. It would seem I need to put something in the gap to keep the bonnet from opening fully (see photos) or adjust something?
Bernie 1966 S1 OTS
#5 Re: Bonnet stop
Post by mgcjag » Sat Nov 03, 2018 1:38 pm
Have you checked the ride height as mentioned above... Steve
#6 Re: Bonnet stop
Post by abowie » Sat Nov 03, 2018 10:50 pm
There is a little bit of adjustment in the balance link position with the captive nuts. You could try moving them about and see what effect this has.
The bumpers should be fitted with wedge shaped washers; it's also possible yours sag a little although it's hard to tell from the pictures.
Otherwise, as above, I suspect your ride height is too low.
Bernie2015
#7 Re: Bonnet stop
Post by Bernie2015 » Sun Nov 04, 2018 8:07 am
Is the front ride height adjustable?
Bernie 1966 S1 OTS
#8 Re: Bonnet stop
Post by christopher storey » Sun Nov 04, 2018 8:16 am
Yes : if you look in the front suspension section of the workshop manual ( knowledge base on this board ) it tells you a. how to measure and b. how to alter the ride height by re-setting the torsion bars in their mountings . It is, however, not a five minute job
Bernie2015
#9 Re: Bonnet stop
Post by Bernie2015 » Sun Nov 04, 2018 8:27 am
Will have a look at that thanks for the pointers not sure what I would do without this website it seems work never stops on the car. About to put a new cylinder head on it which is correct for the year but I will get a professional to do that!
Bernie 1966 S1 OTS
#10 Re: Bonnet stop
Post by malcolm » Sun Nov 04, 2018 10:08 am
I'd go with ride height. From your picture, the angle of the bonnet doesn't look that steep for the overriders to be touching. Also, yours touch right at the base - my bonnet goes much higher so it's more towards the face where they touch if I'm not on a level.
