SU Carb jet locking nut
#1 SU Carb jet locking nut
Hi all
I’m rebuilding my triple HD8s and am trying to tighten the jet housing with the locking nut on the middle carb body.
I find that whilst i am able to fully tighten the nut it leaves the jet housing wobbly
On the other two carbs the nuts tighten the jethousings easily
I then noticed that the problem is that the nut doesn’t screw far enough in to grip the the jet housing
Checking the threads in the carb body I noticed that the problem body has not got its thread cut as deep as the others therefore not allowing the nut to tighten any further
I am attaching photos to compare
I’ve tried every combination just in case I’ve swapped the jet housings/nuts.
I didn’t notice a problem when I stripped them but they had not been used for 30 years and were stuck anyway!
Is this a common problem?
Should I cut a little more thread into the body to match its neighbours?
Advice appreciated
Robbie
Advice appreciated
Robbie
#2 Re: SU Carb jet locking nut
Hi Robbie.....iv rebuilt a few sets and not seen this problem...get in touch with David Lonsdale Classic Carburetters Cirencester, UK 0 7786 912011 he is well known on the forum, a one man band and very helpefull......may be able to provide a replacement body or retap yours.......Steve
#3 Re: SU Carb jet locking nut
Thanks Steve
I’ve done just that, although he’s retired from rebuilds he still has the correct taps and, following receipt of my photos, he will advise on the best plan...probably sending him the offending body for cutting of a slightly deeper thread!
Robbie
Robbie
#4 Re: SU Carb jet locking nut
Yes. It looks like the thread is stripped in one of the holes.
It should be an easy repair using a Helicoil.
'78 Land Rover Series 3 109
#5 Re: SU Carb jet locking nut
Thanks Stuart
Actually the thread is fine. It’s just not deep enough at 7mm
It should go to 8.5 mm at least ...as do the threads in the other two
Robbie
Robbie
#6 Re: SU Carb jet locking nut
I think Stuart is referring to one (the nearest) of the 4 screw threads for the bottom cover.
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#7 Re: SU Carb jet locking nut
Hi Jerry
My mistake..sorry
Actually the threads are all fine it’s probably the focus on the photo
Robbie
My mistake..sorry
Robbie
#8 Re: SU Carb jet locking nut
Hi Friends
David Lonsdale kindly cut another couple of thread circumferences into my throttle body and it’s now perfect
He’s no longer working at rebuilding carbs commercially but he very kindly helped me out
He will give advice over the phone
Robbie
Robbie
#9 Re: SU Carb jet locking nut
Robbie
I had this problem while rebuilding my carbs last winter. The only ditfference being that it was on the slow running screw of the rear carb. I was lucky that the thread turned out to be 1/4 UNF so I was able to cut the extra myself. I can't understand why none of the POs or garages they used hadn't spotted this in the last 50 odd years.
Alan
Alan
Alan Cochrane
