3.8 Indicator white plastic cancelling ring
Topic author - Posts: 23
#1 3.8 Indicator white plastic cancelling ring
Hi everyone,
I realise that this subject has been discussed before, but I am wondering if there is now a supplier of these elusive items?!!
Any help would be very much appreciated.
George Webster
George Webster
#2 Re: 3.8 Indicator white plastic cancelling ring
George:
If you’re talking about the white plastic canceling ring that resides inside the turn signal switch, there’s good news: XK’S Unlimited in the U.S. sells these items for U.S. $19.
Alan
New Jersey
Alan
New Jersey
#3 Re: 3.8 Indicator white plastic cancelling ring
Hi Alan,
Many thanks for the reply, but it's the castellated ring (usually white plastic) that the two 'fingers' from the switch itself engage with to cancel the indicators that I'm seeking.
George
George
#4 Re: 3.8 Indicator white plastic cancelling ring
George:
Understood.
No...I’ve never seen those for sale from the usual vendors here in the States.
Maybe you can find someone with a 3-D printer to make a small batch?
Good luck,
Alan
Understood.
Good luck,
Alan
#5 Re: 3.8 Indicator white plastic cancelling ring
Someone on J-L made one on a 3D printer. Worth checking over there and see if he can make more or offer the data.
S1 OTS OSB; S1 FHC ODB
#6 Re: 3.8 Indicator white plastic cancelling ring
Hi David,
Thanks for the reply and all I have seemed to turn up on the JL site is the smaller white 'spring-like' part that is integral to the switch and not the castellated cancelling ring...
If anyone has a scan of this I'd welcome a copy of the data.
Thanks,
George
Thanks,
George
#7 Re: 3.8 Indicator white plastic cancelling ring
Just been told that Marek makes the cancelling ring. Suggest you PM him.
#8 Re: 3.8 Indicator white plastic cancelling ring
Marek, can you share a photo of the cancelling ring?
Also, I was looking for someone that remakes the plastic end of the indicator stalk - anyone out there does it?..
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#9 Re: 3.8 Indicator white plastic cancelling ring
You'll have to send me your email address - I don't have a copy of it to hand any more. Alternatively, there ought to be some pictures on J-L if you search there.
#10 Re: 3.8 Indicator white plastic cancelling ring
I have one more question on the cancelling ring issue. It seems my striker has the 'tongue ' broken.
It's probably part no c16451.
This is how it looks like:
Anyone has a ring like mine and could possibly measure the total length of this tongue?
I would be most grateful...
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#11 Re: 3.8 Indicator white plastic cancelling ring
Hi Tadek,
Don’t have it to hand so can’t measure it for you, but here is a decent picture to give you an idea:
Cheers.
Cheers.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#12 Re: 3.8 Indicator white plastic cancelling ring
Thanks!
Seems like 26.6-27mm to me.
Cheers, Tadek
Cheers, Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#13 Re: 3.8 Indicator white plastic cancelling ring
Jaguar would have used imperial measures so it will be in inches and/or fractions of inches. Never try measuring anything on an E-Type in metric! That is probably why many reproduction parts don't fit.
#14 Re: 3.8 Indicator white plastic cancelling ring
How does 1 1/16" sound?
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#15 Re: 3.8 Indicator white plastic cancelling ring
1" sounds more correct for a non critical part.
#16 Re: 3.8 Indicator white plastic cancelling ring
Simon,
Does this setup require the plastic ring?? I can't see it in the part's manual..
I have a '63 3.8 and am wondering if I need the plastic cancelling ring - it was not there when I bought te car, but then the steering column was in a mess..
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
