Hitch up the caravan and away you go!!
Tasteful jokes.
TheDampMan
#1 Hitch up the caravan and away you go!!
Post by TheDampMan » Mon Dec 03, 2018 5:26 pm
Any recommendations on what we could tow? :scratchheadyellow:
https://www.ebay.co.uk/itm/Tow-bar-for- ... rk:44:pf:0
1969 Series 2 Roadster
BMW Isetta
#2 Re: Hitch up the caravan and away you go!!
Post by malcolm » Mon Dec 03, 2018 6:10 pm
This perhaps?
Jeremy
#3 Re: Hitch up the caravan and away you go!!
Post by Jeremy » Tue Dec 04, 2018 12:16 am
That caravan would be for quite small people I'm thinking...
Jeremy
1967 S1 4.2 FHC
#4 Re: Hitch up the caravan and away you go!!
Post by chrisfell » Tue Dec 04, 2018 7:48 am
There’s a S2 FHC down here with a two bar AND a caravan.
#5 Re: Hitch up the caravan and away you go!!
Post by Series1 Stu » Tue Dec 04, 2018 11:56 am
The only reason I would fit a tow bar to an E Type is to pull a Riva Motor Launch.
But then, maybe not......
'94 X300 XJR basket case
#6 Re: Hitch up the caravan and away you go!!
Post by mgcjag » Tue Dec 04, 2018 12:00 pm
You could go racing
#7 Re: Hitch up the caravan and away you go!!
Post by chrisfell » Tue Dec 04, 2018 5:15 pm
Series 2 only, it appears. S1 and S3 exhausts might get in the way.
Simon P
#8 Re: Hitch up the caravan and away you go!!
Post by Simon P » Tue Dec 04, 2018 5:24 pm
If it's for towing it's probably intended to attach to the front of an E-type.....
:bigrin:
1969 S2 FHC - 1R20258
