S2 brake calipers for S1.5 car = no fit?
Topic author - Posts: 60
#1 S2 brake calipers for S1.5 car = no fit?
Just checking that series 2 calipers wont fit my series 1.5 car? Series 2 calipers seem to come up on ebay at not too much money, £xx. But If i want better calipers i need to buy 4 pot calipers for £xxx. Is this accurate?
David
#2 Re: S2 brake calipers for S1.5 car = no fit?
I think you will find that these will not fit because the spacing of the fixing bolts differs.
You really have 3 options;
Keep as is
Buy some purpose made 4 pots from the likes of Coopercraft or Zeus
Follow the thread and modify some Volvo 4 pots, although these ar3 getting hard to come buy.
I suppose a 4th option exists in that you could buy some series 2 uprights but that is even more expensive and probably elusive.
Tim
Keep as is
Tim
#3 Re: S2 brake calipers for S1.5 car = no fit?
Are we talking about front rear or both.....Steve
#4 Re: S2 brake calipers for S1.5 car = no fit?
Good point Steve, I had assumed fronts..........
#5 Re: S2 brake calipers for S1.5 car = no fit?
Hi Tim...did you also upgrade your rear brakes....Steve
#6 Re: S2 brake calipers for S1.5 car = no fit?
Yup, series 2 calipers at the rear and 4 pots on the front.
Actually I ended up with a near new complete system. Had to replace the servo, the master cylinder and the vacuum valve on the reservoir.
I think only the front to rear pipes are original !
Made my own remote bleeders - simple job.
Managed to get a good pedal
#7 Re: S2 brake calipers for S1.5 car = no fit?
Thanks for confirming, i was talking about the fronts only, shame about the answer, so i will have to consider 4 pots, good job i did not bid on the S2 calipers, i had read that my front calipers then moved to the rear are an upgrade on my current setup
David
#8 Re: S2 brake calipers for S1.5 car = no fit?
Yes, many people move the front calipers to the rear.
I think it’s an IRS out job ....... others will confirm
If it’s an IRS out job then you may as well check over the entire unit.
Good luck
Good luck
#9 Re: S2 brake calipers for S1.5 car = no fit?
"I suppose a 4th option exists in that you could buy some series 2 uprights but that is even more expensive and probably elusive."
With this option, series 2 steering arms will have to be used as well.
Doug
'67 ots
'67 ots
#10 Re: S2 brake calipers for S1.5 car = no fit?
A long time ago - a fairly normal 'upgrade' was to fit suspension uprights from a 420, they were readily available at the time and that's what I fitted to my Series 1 which allowed me to fit the vented V12 disks too...
Granted that was more than a few years ago when caliper upgrades like Zeus didn't exist - but it *IS* an option :)
1964 FHC 4.2
#11 Re: S2 brake calipers for S1.5 car = no fit?
Chris,
That's good to know however 420's aren't all that common over here. Series 2 2+2's used to be abundant but that's going back to the mid seventies when I got my first E. Many of them gave their lives providing power steering, thicker torsion bars and of course 3-1/2" O.C. uprights, steering arms and Girling brakes.
It's nice having the option now of Zeus and Coopercraft.
Doug
'67 ots
'67 ots
