Wire Wheel Spanner
Topic author - Posts: 170
#1 Wire Wheel Spanner
Having just had my wire wheel spinners (Federal Type) re chromed, I can't quite bring myself to use the original spanner on the new chrome.
Does anyone know if there is a Federal spanner available that will not mark the spinners?
Thank you
Thank you
Simon Brown
1998 XK8 Coupe
2008 Mazda MX-5 2.0 Icon
1991 Mini Cooper 1.3i
1998 XK8 Coupe
#2 Re: Wire Wheel Spanner
Hi Simon...yes you can get an aluminium tool...you will need a large socket and breaker bar to use it....lots of info in this thread....Lionel is the chap that makes them..his contact number is in the last post......for the standard federal style tool i put a thick rag over the spinner then fit the tool (its tight).....then use the hammer....Steve
http://forum.etypeuk.com/viewtopic.php? ... inner+tool
#3 Re: Wire Wheel Spanner
Let us know how you get on Simon. Keen to get a similar tool if they are still available.
I hate the mallet (don’t ask me why!).
Ash
Ash
Series 2 FHC 1970
1R 20607
1R 20607
#4 Re: Wire Wheel Spanner
Just to add that I've one of the Lionel adapter tools and they do a fine job. Steve's comment about a rag is important.
#5 Re: Wire Wheel Spanner
Thanks Guys
Lionel is on holiday at the moment, but will contact me on his return next week.
I will let you know how I get on
Simon Brown
1998 XK8 Coupe
1998 XK8 Coupe
#6 Re: Wire Wheel Spanner
Michel
#7 Re: Wire Wheel Spanner
Hi Mich...the spinner tool is about 3 times the price of the ones Lionel makes....Steve
#8 Re: Wire Wheel Spanner
I know steve but the top quality isn't cheap.
I'm always nervous when the "same" thing cost 3 times less price.
I sell quality tools among others and I see almost every day the "same" 3 or 10 times less price.
But it seems to work pretty well for its price so...
Michel
#9 Re: Wire Wheel Spanner
The torque which Oldtimertools recommends is 258ft.lb
Long tommy bar!
Long tommy bar!
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#10 Re: Wire Wheel Spanner
I bought the one which cost 169.00€ and it's not a big price for the tool I received.
They are obliged to give a so big torque.
1 - They don't want any responsability if there is an accident.
2 - They say by this hight torque that their tool can resist to this.
Intelligent marketing.
Michel
#11 Re: Wire Wheel Spanner
Since the Oldtimers tool is only suitable for fitting the spinners, what do you use for removal?
In fact, when they say the forces required to remove are higher than for fitting, this proves that the spinners tend to self tighten, as discussed previously on this forum.
'78 Land Rover Series 3 109
#12 Re: Wire Wheel Spanner
Oldtimer and Lionel 's tools are both of course for fitting and removal the spinners.
Michel
#13 Re: Wire Wheel Spanner
I've not read the debate on self tightening of spinners.
However, if you tighten any nut to a torque and leave it for a time, it will invariably require a greater break-out torque to undo it. All to do with lube being squeezed out (possibly) but more significantly, static friction (force needed to get it moving) is always greater than moving friction. (going back to physics classes/lab )
Jerome Lunt
2008 MX-5 NC PRHT
2008 MX-5 NC PRHT
#14 Re: Wire Wheel Spanner
That's incorrect Jerry.
Loosening torque is always less than tightening torque due to overcoming friction as the nut etc starts to clamp the joint and then putting stretch into the threaded fastener. Engineering fact.
The reason for undoing often being more difficult than tightening is usually down to corrosion etc.
Mich
The Oldtimers website clearly states that it should only be used for tightening spinners and then used again once the car has been driven a little.
I think I'll stick to my wooden spinner saver.
Mich
#15 Re: Wire Wheel Spanner
Funny!
When a key is usually indicated to tighten 1/2" bolts, what do you use to loosen them?
If you are happy with your piece of wood, it's ok for me. No problems at all.
Michel
#16 Re: Wire Wheel Spanner
My point exactly! What is the point of having one tool to tighten and another method of loosening? It's a waste of money and tool box space.
#17 Re: Wire Wheel Spanner
Dont know what tool you are looking at on the old timers site....but the op was asking about federal type....the Site says for tightening...and ...lossening https://www.oldtimertools.de/Vehicle-Ty ... JA-33.html
#18 Re: Wire Wheel Spanner
Yes, sorry. Having re-read the write up, it says don't use the torque wrench for loosening.
#19 Re: Wire Wheel Spanner
Loosening using a torque wrench will change the setting and not be correct for tightening. 100 foot lbs on the are point will be different and need 95 or 105 foot lbs to move to the 100 foot lbs reading. You will have to calibrate the torque wrench again.
#20 Re: Wire Wheel Spanner
Sorry Geoff, that makes no sense.
