CHASSIS PLATE LOCATION
Davidsmith
#1 CHASSIS PLATE LOCATION
Post by Davidsmith » Mon Apr 29, 2019 3:39 pm
1969 Series 2 4.2 RHD FHC 2+2 - the chassis plate was removed during restoration and subsequently lost. I can get a replacement from SNG but there are several sizes and designs. Which plate size ( and the details that need to be reflected on the plate) is appropriate for this model and where is it fitted ( on the bulk head, on the flat shelf to the right of the battery, on the flat shelf under the throttle mechanism/brake fluid reservoir/next to the air filter)?
Any help appreciated.
JerryL770
#2 Re: CHASSIS PLATE LOCATION
Post by JerryL770 » Mon Apr 29, 2019 5:26 pm
Mine is next to the battery and is approx 17 x 9.5cm
All boxes have stampings including the valve clearances at the bottom.
Jerome Lunt
2008 MX-5 NC PRHT
#3 Re: CHASSIS PLATE LOCATION
Post by Heuer » Mon Apr 29, 2019 5:58 pm
This is from Factory Fit S2 thread:
So same plate and location as the S1 cars; riveted. Later in production the plate changed to a smaller oblong one in the same place and then migrated to the LH side door panel.
S1 OTS OSB; S1 FHC ODB
Davidsmith
#4 Re: CHASSIS PLATE LOCATION
Post by Davidsmith » Mon Apr 29, 2019 8:39 pm
Thanks for the info guys.
Any chance of a full picture of the series 2 chassis plate?
SNG have several examples but the only one of this size is marked "Daimler" and not "Jaguar".
really appreciate your help.
#5 Re: CHASSIS PLATE LOCATION
Post by mgcjag » Mon Apr 29, 2019 9:07 pm
MikeMilton
#6 Re: CHASSIS PLATE LOCATION
Post by MikeMilton » Wed May 01, 2019 10:07 am
I got my replacement here: http://classicjaguar.com/cjparts/dataplate.php
They did a great job.
Just an old guy living by a lake - with a 1969 E-Type FHC, and 1962 OTS
