Hello Jaguar Gearheads,
i got a 64 3.8 coupe. During the last drives the indications of fuel, water temperature and oil pressure gauges go down and then up again to normal readings simultaniously.
What could be wrong?
Thanks for your help.
Best regards
Robert
Gauges show wrong readings sometimes
Topic author - Posts: 15
#2 Re: Gauges show wrong readings sometimes
They are all fed from the same fuse so maybe it is loose?
#3 Re: Gauges show wrong readings sometimes
Much more likely to be the instrument voltage regulator mounted behind the rev counter. Solid state ones are now available to replace the mechanical version.
Mike
1969 S2 FHC
1969 S2 FHC
