Post
by malcolm » Wed Jul 10, 2019 3:20 pm
I use less than a litre on that distance - about 0.8 litres. And mine is a bit oil thirsty, so I reckon yours is using a bit too much. Mine runs very well, no obvious smoke etc, but still using more oil than most. I imagine rings/bores maybe not great? Wouldn't necessarily show in any obvious way. Or valve guides worn - again, car will run well like mine but isn't quite right. If it's running well, you either have to get the head off, and check bores etc, or just keep putting the oil in.
One thought - you did measure the oil level in the same parking place as before? And facing the same way? It's a long engine, and a small variation in gradient makes a big difference on levels at the dipstick.
