Help for the wiring loom
MLBS3V12
#1 Help for the wiring loom
Post by MLBS3V12 » Sat Dec 21, 2019 9:11 am
Hi all,
I'm now working to get the wiring looms back into the car. The problem is that they were not in initially when I've got the car. This is the case for the under dash one and also the one runnng on the right engine frame .
I'm interested to get pictures showing where and how they have to be placed.
Hope someone has this kind of pictures.
Le chemin sera long!...
Colin
#2 Re: Help for the wiring loom
Post by Colin » Mon Dec 23, 2019 11:33 am
Here's a few pictures that might help on the RHS of the frame.
I have uploaded the 3 pictures but not sure if I have done it correctly
PM me if not showing
Colin
S3 1973 V12 2+2 Full restoration
V12 Series III 2+2 1973
Colin
#3 Re: Help for the wiring loom
Post by Colin » Mon Dec 23, 2019 11:39 am
Ill try the photos again
Fingers Crossed
Colin
MLBS3V12
#4 Re: Help for the wiring loom
Post by MLBS3V12 » Mon Dec 23, 2019 3:37 pm
Hello Colin, thank you to share these very interesting pictures.
Exactly what I m looking for.
Do you also have some showing the under dash ?
ManniB
#5 Re: Help for the wiring loom
Post by ManniB » Tue Dec 24, 2019 8:19 am
Hope this helps, Manfred
1972 E type 2+2 Willow Green
MLBS3V12
#6 Re: Help for the wiring loom
Post by MLBS3V12 » Wed Dec 25, 2019 9:26 am
Vielen Dank Manfred,
das hilft sehr :santa:
:thankyouyellow:
vee12eman
Kiribati
#7 Re: Help for the wiring loom
Post by vee12eman » Wed Dec 25, 2019 12:08 pm
Hi Michel,
Is this any help? (Don’t forget of course, that my car is RHD!)
Some before and after shots. I have some more if you need them, some for the radio too, I think I had to make my own extensions for that in order to link the power aerial and a modern (old style) radio with mp3
Series III FHC
vee12eman
Kiribati
#8 Re: Help for the wiring loom
Post by vee12eman » Wed Dec 25, 2019 12:19 pm
Hi Michel,
Here are the radio connections:
And one more of the final fit, prior to fitting the dash top:
Happy Christmas!
Series III FHC
MLBS3V12
#9 Re: Help for the wiring loom
Post by MLBS3V12 » Wed Dec 25, 2019 2:19 pm
Thank you Simon! Happy Christmas too!
I ve finally found back all the pictures you sent me a few years ago on a CD...
:thankyouyellow:
vee12eman
Kiribati
#10 Re: Help for the wiring loom
Post by vee12eman » Wed Dec 25, 2019 6:48 pm
Michel,
Glad to help. Some more photos taken since. Good luck and I look forward to seeing your completed car. I might even ask for some help with an injection conversion ... :scratchheadyellow:
Simon.
Series III FHC
MLBS3V12
#11 Re: Help for the wiring loom
Post by MLBS3V12 » Fri Dec 27, 2019 10:06 am
Last picture from the car
vee12eman
Kiribati
#12 Re: Help for the wiring loom
Post by vee12eman » Sat Dec 28, 2019 3:26 am
Looking good Michel. What a transformation :bigrin:
Series III FHC
jagwit
#13 Re: Help for the wiring loom
Post by jagwit » Sat Dec 28, 2019 7:54 am
I don't see air bleed pipes from the thermostat housibgs to the header tank. Are they yet to be fitted?
Best Regards
Philip
MLBS3V12
#14 Re: Help for the wiring loom
Post by MLBS3V12 » Sat Dec 28, 2019 10:34 am
Hi Philip
I just placed it yesterday.😁
jagwit
#15 Re: Help for the wiring loom
Post by jagwit » Sat Dec 28, 2019 12:43 pm
Please disregard above comment. I became confused with efi t/stat housings and carbed housings.
Best Regards
Philip
MLBS3V12
#16 Re: Help for the wiring loom
Post by MLBS3V12 » Sat Jan 04, 2020 10:20 pm
I m progressing on the re connection and I posting the same picture as many of us, finally at this stage nothing new or special 🤔You just have to know how. 😁
cheqflagsmart
#17 Re: Help for the wiring loom
Post by cheqflagsmart » Tue Mar 31, 2020 3:08 pm
Thanks for these images they are going to help me grately, the only other ones i could use are the washer pump, heater and brake fluid wiring and routing for uk manual ,
MarekH
#18 Re: Help for the wiring loom
Post by MarekH » Tue Mar 31, 2020 3:20 pm
Dear Michel,
While you have all of that apart, cut yourself an access hole and make a cover plate at the bottom front right of the transmission tunnel cover, so you have good access to the clutch slave cylinder and can easily bleed the clutch without dismantling half of the car or having to crawl underneath it to do so.
Colin
#19 Re: Help for the wiring loom
Post by Colin » Wed Apr 01, 2020 11:34 am
Hi Michel
Presuming you have the bulkhead harness C34999 this will serve the washer motor and the secondary brake fluid bottle. Note: There is apparently only 1 bulkhead harness which serves both RHD/LHD. It comes out by the washer motor as per the attached picture shown at the back of the dash. This harness starts and connects to the right hand forward harness just inside the bulkhead engine side. Its a very confusing run as my sparks originally said I had the wrong bulkhead harness but talking to Autosparks/SNG they only ever produced the one type. I have a picture of the run which I attach.
I think the right hand side brake bottle (Mine is auto so you will have the clutch bottle there as well) is served by the right hand forward harness or at least the start of the bulkhead harness (see photo)
Just aside:-
Whilst down at the area where the brake servo is (Left hand side) you have the PDWA Brake Pressure Differential Warning activator.(C37217) which has a lead between that and the brake bottle (C38298). This lead is not available from the normal suppliers and I got mine made up by Autosparks who will supply but I now see Martin Robey is now showing as available.
I think you will also need 2 x C34268 which is the lead between the brake bottles and the connection to the harness which Martin Robey seem to have.
Most of this is from memory so forgive me if I have it wrong but if anybody has a better memory then please add any comments.
Here are the photos no particular order but hope they help-you will need to home in on the photos to see them better.
Colin
Forward Harness joining to Bulkhead Harness Right hand side
Wires coming out by passenger footwell (RHD) Left hand side
Harness going across at bottom right hand side of picture
PDWA
MLBS3V12
#20 Re: Help for the wiring loom
Post by MLBS3V12 » Mon Apr 20, 2020 4:36 pm
Hello Simon,
a last question ( at least for no ) on a green wire on your picture
I dont know what it is for.
