Interior re-trim suppliers?
Topic author - Posts: 73
#1 Interior re-trim suppliers?
I am shortly to commence the interior re-trim of my 2+2. Can anyone recommend a trim supplier? I am aware of BAS International and John Skinner Ltd, and feedback on these 2 companies would be appreciated. I was going to order a complete kit, using the services of a local trimmer, who I have known for years, to do the bulk of the work, including the rooflining. I would possibly do the luggage boards and door cards myself as they look relatively easy...........famous last words!
Tim
Ex US 1970 S2, 2+2 in Ford Colorado Red (formerly Pale Primrose) now right hand drive
(plus 1965 Austin Healey 3000; owned since 2007)
Tim
Thanks.........Tim
1970 ex.U.S. Series 2, 2+2, in course of restoration
#2 Re: Interior re-trim suppliers?
The two you list are very good as are Aldridge in Wolverhampton(who i used for my trim parts)..you may not need a full kit as you will get things that your trimmer will have off the shelf...scrim/foam etc......Steve
#3 Re: Interior re-trim suppliers?
I bought my kit from Skinner. I Worked directly with Jonathon Skinner. Very professional, kit was top-class.
Bob t
#4 Re: Interior re-trim suppliers?
Thanks folks. A bit more feed back on Aldridge's would have been useful. Has anyone out there used them?
I don't know if there is any difference in quality between Skinner's and BAS International. Costwise, from my findings, Skinner's are quite a bit more expensive, apart from a couple of items.
Thanks.........Tim
#5 Re: Interior re-trim suppliers?
As i mentioned above i used Aldridge....couldnt be more pleased...all you have to do is use the search function eg Aldridge....you will find plenty of satisfied customers..same for Skinners, BAS etc... Steve
#6 Re: Interior re-trim suppliers?
Mine was re-trimmed with a full kit from BAS. They were helpful and no problem replacing a door arm rest which fell off when SWMBO lent on it a little. The reinforcing washer was absent.
Then when I requested same materials for re-trimming my MX5 seats and they supplied me with matching leather, vinyl and the perforated leather for my chosen trimmer to use. Mind you, I got far too much leather on their recommendation for normal use so little vinyl got used. I really also needed more of the perforated leather to do the seat squabs properly but that was down to me.
Jerome Lunt
#7 Re: Interior re-trim suppliers?
+1 for BAS in South Wales - always first class material and service in my experience
#8 Re: Interior re-trim suppliers?
Used Aldridge to retrim my seats and centre console. Perfect job and reasonably quick to.
Had a tour of their facility whilst dropping my stuff off, very impressive and they always seem busy.
It wasn’t cheap but I have nothing to compare to.
#9 Re: Interior re-trim suppliers?
I got the full trim kit from BAS but had them do the seats because I was scared of messing them up. They did a superb job and have always been helpful and supportive in all aspects of trimming.
I've only ever heard people complain about 1 trimmer and they have nothing to do with Jaguars so you have a great range of choice available to you.
'78 Land Rover Series 3 109
'94 X300 XJR basket case
#10 Re: Interior re-trim suppliers?
I would recommend GB Classic Trim up in Nuneaton. They've just done a re-trim of my car (new hood and interior below the dashboard).
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#11 Re: Interior re-trim suppliers?
Graham at GB Trim and Aldridge are my preferred trimmers. Their work is amazing.
#12 Re: Interior re-trim suppliers?
I wouldn't recommend BAS these days. Aldridge according to my restorers are considerably better.
#13 Re: Interior re-trim suppliers?
Thanks folks.............all useful stuff.
Will, more than likely, go with Aldridge.
Regards.............Tim
1970 Series 2, 2+2 (undergoing restoration)
Thanks.........Tim
#14 Re: Interior re-trim suppliers?
Are you perhaps confusing BAS here with the BAS in the US ?
#15 Re: Interior re-trim suppliers?
Aldridge left a bit to be desired (I ordered an Etype hood and a Mk10 boot trim kit). But I understand that they also do trimming inhouse which might be a different story. Eric Suffolk, Mick Turley or GB trim would be my choice.
1963 OTS 880436
1963 OTS 880436
#16 Re: Interior re-trim suppliers?
Probably. I had no idea that the US one existed. Sorry for the confusion.christopher storey wrote: ↑Mon Jan 20, 2020 6:43 pmAre you perhaps confusing BAS here with the BAS in the US ?
