Hello all,
I have given up looking to find the correct location of the brake and fuel lines underneath the car, and how they are connected to the chassis. C10268 or just C10406# ?
I cannot trust what we pulled apart is correct and would greatly appreciate help/direction/photos to run these lines correctly in my RHD 3.8 FHC. I’ve attached a picture to where we are up to.
Thanks,
Glenn
Fuel and Brake Lines
#1 Fuel and Brake Lines
#2 Re: Fuel and Brake Lines
Mind run along the offside along your line marked D but I can't be sure mine are right!
#3 Re: Fuel and Brake Lines
Mine are very much the same - on driver's side adjacent to line D
#4 Re: Fuel and Brake Lines
I have always run the fuel line on the drivers side for a RHD car, this is the same side as the fuel filter.
It is fixed with P clips on the outside of the channel ( nearest the sill ) there are holes a long it for that reason.
The brake line goes on the other side also outside the channel & uses special spring clips which you can get from SNG Barratt. The channel also has holes in it.
Hope this helps Neal.
#5 Re: Fuel and Brake Lines
Think 4.2 brake line go along the near side but 3.8 cars with Kelsey Hayes system the brake and fuel lines are on the same side....I think.....
#6 Re: Fuel and Brake Lines
Yes, when I converted my 3.8 from lhd to rhd, the brake & fuel lines originally ran down both the chassis rails, but as the Kelsey Hayes & reservoirs were moving sides, the brake line shifted to the same side as the fuel line - both now on the rhd chassis rail.
#7 Re: Fuel and Brake Lines
Should have read the first post properly as it did say 3.8 car.
What I said is correct for a 4.2 .
Sorry for the confusion .
Neal.
Neal.
#8 Re: Fuel and Brake Lines
Thanks to everyone for their help. I will endeavour to run both down the RHS.
Glenn
Glenn
