Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
#1 Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
A quick question - whom to contact for a set of e-type S1 3.8 hub carriers C20811?
The ones I have have all the bearing races for the fulcrum shaft cracked :-(
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#2 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Tadek : when you say bearing races cracked, are you talking about the roller cages themselves, or do you mean the aluminium housing into which they fit ? The roller cages are relatively easy to replace with new ones
#3 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Hi Tadek...i see you have also posted in the wanted section....if its holding up your build you could use any of the aluminium hub carriers....they all use the same size bearings....xj6 S1-3 is a good source and around £50 each...Steve
#4 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Thanks, but they all seem to have different part numbers - are there any major/important differences?
What about the geometry (fulcrum pin to hub bearing distance) ??
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#5 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Hi Tadek...yes they all have different part numbers and have dlightly different moulding shapes....but as far as im aware the geometry is the same....obviously E type ones will be much harder to find second hand....you can buy new castings.......I had two both with cracks....and replaced them from an XJ6..all bearings etc same as E type..my reasearch pointed to them functioning the same but looking slightly different......dont go for later xj6 as they have a fitting for ABS sensor.......best to do your own reaserch starting here then make up your own mind.....Steve
#6 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Chris,
Pardon my confusion - It's the aluminum housing that's cracked, unfortunately..
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#7 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Hi Tadek...just for info.....its not uncommon for these carriers to have cracks.....when you get these second hand they are covered in dirt/grease etc and still have the old bearings in...the first pair i purchased after cleaning and removeing the old races were found to have cracks.....fortunatly i got them from a well known used Jag parts supplier who sent me more.......i found that once cleaned up it you brush petrol over them it will highlight cracks they can be anywhere like this one
#8 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Thanks Steve! I will check it.
Can you pm me on the possible supplier?
Regards, Tadek
Regards, Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#9 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Hi Tadek...this is his ebay link...but if you look at the bottom he does give contact details...name John Gordon...i have no association to him but he was very good to deal with....however im sure you should be able to get these more local to you....Steve https://www.ebay.co.uk/itm/JAGUAR-DAIML ... SwcBhWWcFW
#10 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Yes, I have also dealt with John Gordon and would be quite happy. There is also a scrapyard in Rhollanerchrugog, North Wales who do a lot of XJ6 scrapping . The name is Dave Kelly and here is the website
http://www.cylex-uk.co.uk/reviews/viewc ... d=16862517
#11 Re: Whom to contact for a pair of e-type S1 3.8 hub carriers C20811?
Chris, Steve,
Many thanks for the tips!
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
