Spinners stuck and wheels stuck on!
#41 Re: Spinners stuck and wheels stuck on!
Post by rswaffie » Thu Mar 19, 2020 11:49 am
No mods needed, no rubbing and no issues fitting in the spare wheel well. They look painted rather than powder coated and there are some patches where the paint has been chipped off, showing the red primer, so I would attend to those areas if I was keeping them. I’m hoping to swap them for the chromes tomorrow so I’ll photo everything and you can see what you think. I’ll price them once I’ve had a good look at them all.
Jonny XKE
#42 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 19, 2020 12:10 pm
OK thanks Richard
S1.5 FHC 4.2 OSB 1968
#43 Re: Spinners stuck and wheels stuck on!
Post by Gfhug » Thu Mar 19, 2020 1:48 pm
Normally 205 tyres need the rear bump stop grinding off or the tyre can scrape against it, did on my car and failed an mot on it
Jonny XKE
#44 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 19, 2020 4:03 pm
Long story but ended up buying 4 as new dunlop chrome wire wheels for £550.
Lets hope I look after these a bit better! I think the problem was that I hadn't dried my previous set properly when putting away in the garage. I may also avoid using a pressure washer on them.
Jonny XKE
#45 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 26, 2020 2:22 pm
Why is it never simple!?
I got my lovely new wire wheels today and put them on. I was very pleased with myself until I drove it. The Zeus oversized brake calipers are "just" touching the wheel. The previous wire wheels must have been slightly different. I either need a very slender spacer to bring the wheel out a bit or I need to grind the caliper which I really don't want to do. Do spacers exist for e-type wire wheels? what would you guys do?
#46 Re: Spinners stuck and wheels stuck on!
Post by mgcjag » Thu Mar 26, 2020 2:28 pm
You can get a 3mm spacer from Realm Engineering.....fits between hub and disc and then space your caliper then just hope its enough or grinder time Steve
Jonny XKE
#47 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 26, 2020 2:35 pm
I've noticed that the caliper was grinded before by the previous owner. I wonder if it already has a spacer on it but the owner had to grind as well. Are the spacers easy to fit?
May be easier to increase the grind on the calipers as they are already showing. Can you grind in situ and what would I need as I don't have a grinder. What I mean is what type of grinder would do the job?
#48 Re: Spinners stuck and wheels stuck on!
Post by Heuer » Thu Mar 26, 2020 2:42 pm
Did you get the Zeus iron calipers or the alloy ones? If the latter you would be better off putting them on eBay and buying the former.
S1 OTS OSB; S1 FHC ODB
#49 Re: Spinners stuck and wheels stuck on!
Post by mgcjag » Thu Mar 26, 2020 2:54 pm
Hi Jonny.....your problem does need a close look at......is it happening on both sides of the car....you purchased used wheels....is it just one wheel or do they all rub(try them all on the front).so is it a bent wheel......the hub is in a fixed position mounted on the stub axel with its bearings.....the spacer i refer to fits between hub and disc so actually moved disc inboard then you would need to move the caliper inboard.....a 4in disc cutter with a grinding disc on will do the job or a dremmel or just a good file...Steve
tim wood
#50 Re: Spinners stuck and wheels stuck on!
Post by tim wood » Thu Mar 26, 2020 2:59 pm
Seem to remember this happening elsewhere, calipers were sent back for modifying.
Must be on the forum somewhere
Jonny XKE
#51 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 26, 2020 3:02 pm
Thanks Steve, I tried the spare wheel which is one of the original wheels and that is a papers width from the caliper but clears. The new one rubs on it slightly. Its not the wheels its the after market brake calipers. The used wheels had hardly been used and were supplied by someone who makes wire wheels so they should be good anyway and I trust him. I'm going to buy a grinder .. never used one before. Does this one look ok?
#52 Re: Spinners stuck and wheels stuck on!
Post by mgcjag » Thu Mar 26, 2020 3:11 pm
Yes that looks ok.....but first with the wheel off is the caliper mounted so the disc is central....there could be scope to slightly shim the caliper over....pm sent....Steve
Jonny XKE
#53 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 26, 2020 3:32 pm
Hi Steve,
Please see below images.
Jon
#54 Re: Spinners stuck and wheels stuck on!
Post by mgcjag » Thu Mar 26, 2020 4:09 pm
Hi Jonny....best to wait a while for more input just to see what others have done or start a new post on Zeus calipers...be cautious with a grinder you could go through.......Steve
Jonny XKE
#55 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 26, 2020 4:57 pm
Thanks Steve and will do
MarekH
#56 Re: Spinners stuck and wheels stuck on!
Post by MarekH » Thu Mar 26, 2020 6:55 pm
Are you seriously going to hand grind a caliper to make it fit something it doesn't fit to? I would take it to a machine shop who will put it onto a lathe bed accurately FLAT so they can mill the correct amount off. The same will go for a spacer. You can't guarantee it will be level if you do this by hand. In fact you can more or less guarantee that it won't be.
Do consider how tight this has to be bolted in - it absolutely must be flat. Then consider the massive force that joint and those bolts are under every time you hit the brakes. Running skew fitted DIY brakes is madness.
And the machine shop option will probably be cheaper than the purchase cost of a decent power tool.
#57 Re: Spinners stuck and wheels stuck on!
Post by Series1 Stu » Thu Mar 26, 2020 7:09 pm
Surely that vented disc isn't standard!
I would review the whole set up because it just looks wrong to me.
Do you have curly or flat hub wheels? I suspect the former and if you fit flat hub your problem might disappear without resorting to any kind of vandalism on the brake calipers.
'94 X300 XJR basket case
Jonny XKE
#58 Re: Spinners stuck and wheels stuck on!
Post by Jonny XKE » Thu Mar 26, 2020 7:15 pm
The brake set up isn't wrong. Its a Zeus upgrade kit that includes the disc. Although not his, Peter Cooper from Coopercraft works on the car and he hasn't mentioned that it looks wrong at all. I'm not changing the wire wheels again! Each wire wheel will vary slightly so going to swap them around to see if they clear the caliper.
#59 Re: Spinners stuck and wheels stuck on!
Post by mgcjag » Thu Mar 26, 2020 7:31 pm
You do realise that wire wheels have an off set and a backspaceing and the center hubs can differ...this effects the spoke position ...would be worth knowing how your originals compare to your new ones.....all these details can be looked up on the MWS website ...just for info this is the type of info im refering to...note its a hub from a 16in wheel but just for referance
#60 Re: Spinners stuck and wheels stuck on!
Post by PeterCrespin » Fri Mar 27, 2020 12:43 am
I assumed Johnny was talking about touching the inside of the rim, not the hub?
