Radiator foam seal
#1 Radiator foam seal
Post by mgcjag » Sun Feb 06, 2011 10:48 am
Hi Guys......69 S2 2+2......should there be a foam seal on top of the radiator.....the SC Parts catalogue showes one as part no SJ 10746....but havent seen one on another car......any ideas...thanks. Steve
Post by christopher storey » Sun Feb 06, 2011 11:46 am
AFAIK , the foam ( or more accurately felt) seal should go on top of the radiator stoneguard, not the radiator itself
Francis
Post by Francis » Sun Feb 06, 2011 10:27 pm
Check this e-bay listing, on the pictures you will see it:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... K:MEWAX:IT
Francis
69 OTS S2 1R8482 named Fiona
Post by mgcjag » Mon Feb 07, 2011 10:12 am
Hi Guys the foam i refer to is shown in the s c parts catalogue as item 9 as below any one seen one & is it required Steve http://www.scparts.co.uk/index/lang-2/l ... pl,x-a.htm
Post by christopher storey » Mon Feb 07, 2011 11:56 am
I have never yet seen a car with one, ( but I am not very familiar with S1.5) but frankly it seems rather pointless, since the only object is to force air through the radiator, and it can still go round the sides . I certainly would not regard it as a priority - my S2 has not had one in the 15 years I have had it!
Post by Heuer » Mon Feb 07, 2011 12:06 pm
If Jaguar put a seal on there was probably a very good reason for it given the penny pinching Mr Arthur Whittaker was in charge of purchasing! For ?20 you may as well put it on if only from the originality point of view.
S1 OTS OSB; S1 FHC ODB
Post by christopher storey » Mon Feb 07, 2011 12:14 pm
I stick to my guns on this. I do not believe this is an original part. The car which Frances has used as an example ( just added to XKE data by the way ) has no stoneguard and thus no felt seal above it . This looks to me like a bodge to overcome that problem . If anyone has a Haddock book it may reveal whether they were fitted to S1.5 at the time
Post by Heuer » Mon Feb 07, 2011 2:24 pm
Nothing in Haddock on the subject but the SC Parts catalogue (which is excellent in its detail) list the part number as BD31996 which is a Jaguar one given that, for example, part BD36788 is listed by SNG as "E-Type S2 Genuine Jaguar bonnet".
Post by christopher storey » Mon Feb 07, 2011 3:13 pm
David : most interesting. Barratt's do not show anything , but Manners do,(although not from stock) and at ?24 it's more substantial than the V12 seal which they list as BD34365. It sounds as though there is such a part which fills the gap between the later ( lower than S1) radiator and the bonnet
andy303
#10
Post by andy303 » Mon Feb 07, 2011 5:49 pm
It was definitely used. You can see it in some of the open bonnet views in the the Brooksland Books Ultimate Portfolio road tests articles, IIRC most easily spotted in Road and Tracks test of the '69 S2 FHC. The stone guard is still used. Obviously it is meant to maximize the volume of incoming air through the radiator core. Perhaps it is meant to help when stuck in traffic to increase the effectiveness of the fans when stopped or moving slowly.
Andy Blackley
Chardon, Ohio
69 S2 2+2 http://www.xkedata.com/cars/detail/?car=1R41606
Fear God and Dreadnought
kingzetts
Post by kingzetts » Mon Feb 07, 2011 8:10 pm
When I fitted a stoneguard to my '62 I used a length of foam insulation of the type used on 15mm domestic copper plumbing pipe along the top edge rather than buy the "correct" part. Cost nothing since I already had some in the shed and although it may not be "correct" it does the job.
John '62 S1 OTS (now sold)
Simon P
Post by Simon P » Mon Feb 07, 2011 8:52 pm
You'll find clear shots of it on p.88 of DSJ's book (B&W), and p.72 of Philip Porter's Collector's Originality Guide (colour).
Francis
#13
Post by Francis » Wed Feb 09, 2011 12:44 am
Speaking of the devil:
http://cgi.ebay.com/ebaymotors/0996-Jag ... 3364ef294b
For $28.- on e-bay
Francis
Post by christopher storey » Wed Feb 09, 2011 4:16 am
The V12 seal is available for ?8.86 = $13 Us from Manners!! I wish I could buy at $13 and sell at $28
Red Kite
Post by Red Kite » Mon Jun 02, 2014 1:45 pm
I'm looking at this one, seems good value.
http://www.terrysjag.com/product/BD31996.html
Gerry.
S2 FHC 1R20003
Simon P
Post by Simon P » Mon Jun 02, 2014 4:35 pm
The JCNA guide says that grey ones are 'not correct' and that they should instead be tan. Admittedly grey looks better than tan, the JCNA guide is not always infallible, and as long as it soes the job it's mean to do with the bonnet shut you can't see it anyway...
johnney
Post by johnney » Tue Jun 03, 2014 3:44 am
Definitely tan coloured, the guide is correct. My late series one (1968) still had its original foam seal when I bought it and it was tan coloured the same material and colour as the insulating foam on the top of the gearbox.
johnney
1968 FHC series 1
1E21862
