I was digging thru some parts I have and came across this ring set.
Would these be for a 3.4 litre engine?
Thanks,
Mike
Hepolite Ring Set # 2555
#1 Hepolite Ring Set # 2555
#2 Re: Hepolite Ring Set # 2555
Someone must know!
#3 Re: Hepolite Ring Set # 2555
That bore is consistent with both the 3.4 and 2.4 liter versions of the XK engine. But as to ring thickness and count, and therefore compatibility with specific pistons, I think you will need to find some Hepolite documentation to give you a definitive answer as to which specific application they are for.
#4 Re: Hepolite Ring Set # 2555
Hi Mike,
All I can tell you from my Mk2 manual is that 3.2677 is the size of the cylinder bores of the 2.4 and 3.4 Mk2.
The 3.8 is 3.4252.
Hepolite are not standard fit pistons, at least not on the Mk2, Brico is.
The 3.8 is 3.4252.
#5 Re: Hepolite Ring Set # 2555
Sorry Steve; you answered this while I was still typing
#6 Re: Hepolite Ring Set # 2555
Thank you!
Mike
Mike
