Oil filter bolts
phoenix
#1 Oil filter bolts
Post by phoenix » Sat Jan 09, 2021 10:26 am
S 1 4.2 .Hi I am just fitting the oil filter housing and I noticed a bolt hole at the centre bottom on the block with no corresponding hole in the fitting . Is this OK ( it has the spin on conversion fitted which I took off and checked behind)
S1 4.2 RHD Bryan
steve3.8
#2 Re: Oil filter bolts
Post by steve3.8 » Sun Jan 10, 2021 10:42 am
There should be a slotted grub screw in the spare tapped hole to blank it off --.
Steve3.8
64 3.8 fhc, 67 4.2 fhc
phoenix
#3 Re: Oil filter bolts
Post by phoenix » Sun Jan 10, 2021 11:47 am
Thanks for that Steve.
S1 4.2 RHD Bryan
