FACTORY FIT - Series 1 4.2
#41 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Mon Apr 29, 2019 12:33 pm
This is a 1964 one owner car with 26,000 miles on the clock and then for 40 years. Lots of interesting original detail and the only disappointment is the missing toolkit:
Some points worth noting:
Screws holding headlamp surrounds and side lights are slotted
Five way terminal for wiper motor is held in place with strapping - the 3.8 had a metal bracket
Early style heater box grill retainer
Position of latches with bonnet closed and locked
More photo here: https://lbilimited.com/offerings/1965-j ... -roadster/
S1 OTS OSB; S1 FHC ODB
#42 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Mon Apr 29, 2019 1:57 pm
Seen on the above car is this cloth label on the battery terminal lead.
We have seen it before on the underside of the Hardura of Steve's car:
Seat belts also labelled:
ysmalkie
Poland
#43 Re: FACTORY FIT - Series 1 4.2
Post by ysmalkie » Tue Apr 30, 2019 10:50 am
For those who want to have a copy: all photos in one zip file:
https://drive.google.com/open?id=19fdDy ... S7XmLuvO9x
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
ralphr1780
#44 Re: FACTORY FIT - Series 1 4.2
Post by ralphr1780 » Tue Apr 30, 2019 12:05 pm
Nice pics.
But I really find it hard to believe this car covered only the stated low mileage, given various details.
Is it the car of the Beverly Hillibillies? :bigrin:
Ralph
'69 OTS + '62 OTS - Belgium
#45 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sat Sep 14, 2019 11:16 am
1967 E-Type unrestored:
#46 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sun Apr 26, 2020 2:10 pm
Tool Kit
All S1 4.2's left the Factory with a full tool kit which was wrapped in a clear plastic bag (see post #24). If a tool kit was subsequently ordered from the Spares Department it had the part number 11610 and was shipped in a brown bag. The Girling bleeder tin suggests this kit dates from late 1967:
#47 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Tue May 25, 2021 2:36 pm
Spark Plugs
The 4.2 cars were fitted with Champion N-5 sparking plugs by the Factory. These were changed from engine 7E10447 to N-11Y plugs due to complaints of plug fouling at low speed. The same problem occured with the 3.8 engines and the plugs were changed from N-5 to N-12Y in December 1962. Odd the Factory persevered with the N-5 -plugs on the 4.2's.
N = 14mm thread, 3/4" reach, 13/16" hex
5 = heat range, 11 is hotter
Y = Projected Cone Nose electrode
C = Copper core
Maikel
#48 Original gear knob on 4.2
Post by Maikel » Fri Oct 21, 2022 6:40 am
Good day everyone,
we had that before and I am still confused.
Could be that the original gear knob changed at some point.
Which of the three is the original? Or are two of them are original but at different period?
Whoever of you still has the original for 100% might please post a picture of it here.
Many thanks
Maikel
#49 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Fri Oct 21, 2022 10:27 am
No, the gear knob changed during 4.2 production. The one on the right in your photo is Factory correct with the flat topped 3. An original shift knob measures 1.66" (42mm) in diameter, weighs 8.1 oz (230 gms) and the core is non-magnetic; most repros are magnetic and weigh about 5oz (140 gms).
Original:
Repro left has magnetic thread, original right has non-magnetic thread:
Maikel
#50 Re: FACTORY FIT - Series 1 4.2
Post by Maikel » Fri Oct 21, 2022 2:02 pm
Thank you David,
that confuses me even more.
The left one is non magnet and 1,681" neqr 230 gr
The center one is non magnetic and 1.699" near 200 gr
The right one is magnetic and 1.618" near 150 gr
I can not imagine they are all repros.
Can someone who has for sure an original post some pics.
Could one of them be of a S2
#51 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Fri Oct 21, 2022 4:10 pm
All 4.2 onwards cars S1/S2/S3 had the same knob - C23007 - AFAIK. This is a photo from Clausagers Factory Original book. The rubber gaiter means it was pre October 1966 production.:
It was discussed at length here: viewtopic.php?f=4&t=13140&p=107339 although interestingly one of the knobs measured had the same '3' as yours:
I can find no record of any change.
Incidentally this shows what is under the plastic knob:
We need more data!
44DHR
#52 Re: FACTORY FIT - Series 1 4.2
Post by 44DHR » Sat Oct 22, 2022 10:01 am
For my four pennyworth !
I have had my 1967 4.2 FHC for over 20 years now and one thing I decided was that I would always retain the gear knob which came with the car as the thought that anyone who had driven the car would have made contact with the car through that key part appealed to me. It is one of the final 60 Series 1 FHC cars built according to the chassis number.
Although the gear knob is well used with no white paint evident and it has a crack in the black plastic, I still keep it on the car as I believed it to be the original one from 1967 and had no reason to doubt it.
Although all the parameters above are met, it is heavy at 230 grams, has a non-magnetic insert and is 1.662 inches in diameter, the number “3” is not flat topped. So effectively it is the same as Maikel’s one on the left in his post #48 above with the specifications of it in his post #50.
Photos below :-
The mystery deepens ?
Dave Rose
1967 Series 1 4.2 FHC
#53 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sat Oct 22, 2022 1:56 pm
It could be a change of supplier or the original mould was damaged and remade with a different font. Of course it could be the rounded 3 is the original and the flat 3 is the repro.
Keep the data coming to see if we can pin it down to a year.
Maikel
#54 Re: FACTORY FIT - Series 1 4.2
Post by Maikel » Sun Oct 23, 2022 12:03 am
Aha .....
thank you 44DHR,
Very intetesting. So yours also has the round 3 but also the lining of the gear pattern is on the outer edge of the R and 3 and 4. ( not pointing to the middle of R, 3 and 4)
So, we do have 4 different knobs already.
Some more out there with an original gear knob?
#55 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sun Oct 23, 2022 10:52 am
Jaguar used a font with a flat topped 3 on the 3.8 gear knob which it would seem logical they would continue using:
The 4.2 style knob was fitted to production cars for nine years so perhaps not surprising there are variations. From what I can find I believe the knobs were made by Streetly Manufacturing Co of Streetly, Sutton Coldfield, near Birmingham. They manufactured Plastic Mouldings for the trade in Beetle Urea and Melamine, Phenolic and Thermo-Plastic materials and were part of British Industrial Plastics who produced resins and moulding powders.
Jeremy
#56 Re: FACTORY FIT - Series 1 4.2
Post by Jeremy » Sun Oct 23, 2022 2:30 pm
I would love to contribute as mine is 25 Apr, chassis no 1E21509, and retains its unquestionably original knob; but 103,000 miles (also unquestionable) of caressing have taken their toll, and the extremities of the numerals have long since faded into the mists of history... :shrug:
Jeremy
1967 S1 4.2 FHC
44DHR
#57 Re: FACTORY FIT - Series 1 4.2
Post by 44DHR » Sun Oct 23, 2022 3:21 pm
Jeremy, my car was manufactured on the 3rd May 1967 and therefore very close to your April 1967 FHC.
I have never questioned that my gear knob was not the original factory supplied item and despite you not being able to read the complete numbers clearly, perhaps the interesting thing is that your gear knob also has the “gate” markings offset outside the centre lines of the “R” and the “3” and 4”, as mine has.
Perhaps this “gate” marking is a key delineator ?
Dave Rose
#58 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sun Oct 23, 2022 3:54 pm
The Clausager photo is of an April 1965 car so the knob design changed sometime after that. This is car 1E20139 late Dec 1964:
Jeremy
#59 Re: FACTORY FIT - Series 1 4.2
Post by Jeremy » Sun Oct 23, 2022 4:01 pm
We are only 8 days apart Dave. My date of manufacture is 25 Apr, chassis no 1E21509.
Jeremy
1967 S1 4.2 FHC
44DHR
#60 Re: FACTORY FIT - Series 1 4.2
Post by 44DHR » Mon Oct 24, 2022 9:51 am
Hi Jeremy,
My Chassis number is 1E21525, so very close.
We are next to each other in the Jaguar E Type Register !
Cheers,
Dave Rose
