Cooling fan relay questions
No Quarter
Denmark
#1 Cooling fan relay questions
Post by No Quarter » Fri Oct 20, 2023 12:47 pm
Wiring loom installed, almost, down to the details.
1. Picture shows the cooling fan relay, right?
2. How is it to be attached? I can't see any attachment points near for the two holes. I'm sure bracket C28134 will do the trick, but everywhere I see it, it's named for 4.2 only, so how was the relay attached on our 3.8s?
3. Wires are numbered 1, 2, 3 etc, not visible on my relay, where can I find schematic of the 5 legs?
Mikael
63 E-Type, 81 XJ6, 03 X-Type, 07 XKR
09 CTS-V
78 Longchamp
Author of "Tuning Made Easy"
dlgis
#2 Re: Cooling fan relay questions
Post by dlgis » Fri Oct 20, 2023 3:21 pm
Here’s a pic of the back of the relay which might help:
Darryl
caveman
#3 Re: Cooling fan relay questions
Post by caveman » Fri Oct 20, 2023 6:45 pm
1965 S1 4.2 FHC (early)
caveman
#4 Re: Cooling fan relay questions
Post by caveman » Fri Oct 20, 2023 7:06 pm
Position for later cars:
viewtopic.php?t=14684
#5 Re: Cooling fan relay questions
Post by mgcjag » Fri Oct 20, 2023 7:08 pm
The original poster if after the location of the relay...not the wireing details....had a quick look in the 3.8 factory fit section and found this....Steve
caveman
#6 Re: Cooling fan relay questions
Post by caveman » Fri Oct 20, 2023 7:13 pm
[quote
[/quote]
You may want to read OP thoroughly.
No Quarter
Denmark
#7 Re: Cooling fan relay questions
Post by No Quarter » Fri Oct 20, 2023 7:15 pm
Thanks, great answers on wiring. Not understood positioning yet. I use the original wiring, which is in remarkable condition, and the relay has to be placed on the left side, 15-25 cm in front of starter relay. I just donøt see anything to attach it to. And remember the reason for most of my questions, I didn't take it apart, I bought it in boxes. The next E-Type will be easier :lol:
Mikael
09 CTS-V
78 Longchamp
#8 Re: Cooling fan relay questions
Post by mgcjag » Fri Oct 20, 2023 7:16 pm
Yes your correct my mistake....Steve
caveman
#9 Re: Cooling fan relay questions
Post by caveman » Fri Oct 20, 2023 7:24 pm
No Quarter
Denmark
#10 Re: Cooling fan relay questions
Post by No Quarter » Fri Oct 20, 2023 7:26 pm
It's LHD BTW
Mikael
09 CTS-V
78 Longchamp
#11 Re: Cooling fan relay questions
Post by mgcjag » Fri Oct 20, 2023 7:27 pm
Have a look here.....post 98.....note relay was not used on later 3.8 cars...Steve viewtopic.php?f=4&t=2006&start=80
caveman
#12 Re: Cooling fan relay questions
Post by caveman » Fri Oct 20, 2023 7:30 pm
It's LHD BTW
Just swap to other side :lol:
No Quarter
Denmark
#13 Re: Cooling fan relay questions
Post by No Quarter » Fri Oct 20, 2023 7:50 pm
If the relay is to be able to reach the wiring ( :bigrin: ), it has to be attached somewhere in the yellow area. Would hate to drill unnecessary holes...
Is there not a reasonable original LHD 3.8 out there to look at? I have a handful of helping people with E-Types here in Denmark, but all 4.2 or V12
Mikael
09 CTS-V
78 Longchamp
ralphr1780
#14 Re: Cooling fan relay questions
Post by ralphr1780 » Sat Oct 21, 2023 6:28 am
On the LHD the relay remains in the same position/location as in above pics: on the right side under the header tank.
Ralph
'69 OTS + '62 OTS - Belgium
Allrand
#15 Re: Cooling fan relay questions
Post by Allrand » Sat Oct 21, 2023 7:07 am
Here it is on my 64 3.8.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#16 Re: Cooling fan relay questions
Post by Series1 Stu » Sat Oct 21, 2023 12:49 pm
Is it possible, Maikel, that you have the horn relay which is mounted on the inside of the left hand mudguard, just ahead of the starter solenoid?
'78 Land Rover Series 3 109
No Quarter
Denmark
#17 Re: Cooling fan relay questions
Post by No Quarter » Sat Oct 21, 2023 2:10 pm
Could be horn relay if horn relay is still placed there if car is early enought to have horns placed beside headlights in bonnet?
Mikael
09 CTS-V
78 Longchamp
#18 Re: Cooling fan relay questions
Post by Series1 Stu » Sat Oct 21, 2023 8:31 pm
Yes, mine is a (very) late '62 FHC and has the horns in the bonnet and the relay on the mudguard.
#19 Re: Cooling fan relay questions
Post by DWW » Sat Oct 21, 2023 9:42 pm
Mine too.
No Quarter
Denmark
#20 Re: Cooling fan relay questions
Post by No Quarter » Sun Oct 22, 2023 3:20 am
Think I got what I need now, a few days before I can get to it to try it...
Mikael
09 CTS-V
78 Longchamp
